Toshiba 32AV502R LCD TV Logo
Anonymous Posted on Jul 14, 2013
Picture just cuts out; sound stays on; rebooting everything doesn't help
bobby caesar
Level 2:
Champion:
  • Expert 247 Answers
  • Posted on Jul 14, 2013
bobby caesar
Expert
Level 2:
Champion:
Answers
247
Questions
Helped
28538
Points
498
Check the video amplifier and lcd backlighting they may be faulty
No picture.
Try posting to TV category. It may need a ride to the TV Tech?
No picture just black screen
sounds like the lamp went out in it. change lamp and u should get sound and picture
Sony KDL-V32XBR1 Displays only snowy picture
Here are a few more troubleshooting steps you can try when your TV picture is just snow. I see that you have already rebooted your TV, but did you turn your set-top box off and on, too?
1. Does the picture show when you play a DVD?
2. Check all of the connections between the TV, outlet and set-top box and make sure everything is secured.
3. Is your TV set to the correct channel (typically 3, but in some areas 2 or 4)?
4. Press any key on the remote to see if the correct mode lights up. (Ex: if you have cable, the cable button should light up). If it doesn't, press the correct mode's button to regain control and change channels.
5. Call your service provider and make sure it's not an overall service outage.
6. Do you have sound but no picture? If so, it could mean a backlight failure.
For more suggestions, see TV black screen or snowy screen for troubleshooting and solutions. I hope this helps!
1helpful
PH-50T18 Prima The picture doesn' twork. Sound works. any suggestions
There is a power supply failure and this might need attention of a qualified service technician
I am trying to scan pictures through MP Navigator and but when I go to press scan documents, it says, unable to connect with the scanner, scanner may not be turned on or a cable may be disconnected..i have...
First I'd try rebooting your computer with the printer on and plugged in ( reboot the printer first ). I know that sounds simple but it works sometimes.
If that doesn't work, make sure you do have communication with the printer. Can you print to it? If you can, I would reinstall the printer drivers, as the scanner driver may need to be reinstalled. http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp150#DriversAndSoftware and choose your operating system for the driver.
If this solution helps, please give a positive rating.
When I turn on the laptop nothing happens at all, the power light comes on along with some others as normal then the machine cuts out and attempts to reboot again and again. The bios doesn't even post...
If there is no picture on the lcd and you can hear that the laptop is restarting, that has to be the graphics card of your notebook. Needs fix or replacement. Refer to a computer technician near your home. The cost for fixing the graphics card is between 40 - 60 dollars. If it wants a replacement, then there is a lot of money that you have to spend on your notebook. Please rate my help! Thanks!
Went out no picture sound nothing
no picture no sound nothing but when connect conputer have picture and sound plese help thank
My Hp Pavilion dv4000 screen stays blank
have you got a bootable cd or recovery cd , boot from it and do a fresh installation, i think your windows has got corrupt
Picture cut
Sounds like a bad panel, although the audio problem is puzzling. When you say "cut off" is half the picture missing? A better description would help
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
