JVC HD-52G886 52 in. Rear Projection HDTV Television
Problems with JVC HD-52G886 52 in. Rear Projection HDTV...?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
JVC HD-52G886 52 in. Rear Projection...
Troubleshooting and Support
Solved Problems for JVC HD-52G886 52 in. Rear Projection HDTV Television RSS Feed
View More Results for JVC HD-52G886 52 in. Rear Projection HDTV Television
Questions and Unsolved Support Problems
Unsolved Problems for JVC HD-52G886 52 in. Rear Projection HDTV Television RSS Feed
Answer
I have an JVC HD52Z575 seems outlet was crushed during storm Fuse on power board was replaced to not... (More)
Answer
jvc hd-52g886 i turn it on but black picture and blue and red lights are flashing?
Answer
I turned the tv on and it goes through it's warm up and them the blue light and red led just flash... (More)
Answer
Hello, I have a JVC 52 in TV with one HDMI port. It just stopped working. I had a repair man fix it... (More)
Answer
I have a JVC 52g886. TV was working fine, turned it off one morning and when turned back on that... (More)
Answer
where do i find the model number for my jvc projection hdtv? all i know, it's a 52" but can't... (More)
Find a Manual
JVC HD-52G886 52 in. Rear Projection HDTV Television Manuals & Guides
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
Tips & How To Guides for the JVC HD-52G886 52 in. Rear Projection HDTV...
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
Why my TV does not start up and remains in standby?
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also ensure that the fault is not coming from a faulty receiver... written by ginko
Mitusbishi shuts off instantly...
Most of the Mitsubishi rear projection sets made from about 2000 through 2006 have a self diagnostic check feature. It will indicate if there is a... written by SD Tech
Mitsubishi Green Blinking light of death
This information applies to Mitsubishi sets that have a Model number beginning with VS, WS, WT etc. It does not apply to the WD series of sets made... written by SD Tech
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W..,...
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W.., D56W.., D61W.. · Symptom: No Convergence, Picture is bowed and distorted,... written by johnnydiode
Samsung Color Wheel replacement!
This varies a little depending on model number of the set. Usually a bad color wheel will produce a high pitched sound or even a grinding noise; some... written by SD Tech
Sony KP51hw40 etc with Blue screen and or Shuts down
Many of these sets had problems with bad picture Tubes--they use a red, green and blue crt. Most commonly the blue gives troubles--The tubes are now... written by SD Tech
PANASONIC CONVERGENCE DO IT YOURSELF REPAIR
So many people ask me about this here are my Instructions if convergence will not adjust and or is skewed: PANASONIC CONVERGENCE... written by SD Tech
Solution for Video looking whiteish, dull, or too red
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D... written by Ecollier2012
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for JVC HD-52G886 52 in. Rear Projection HDTV Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Ratings for the
Find a Warranty
Specifications for JVC HD-52G886 52 in. Rear Projection HDTV Television
Key Features
Screen Size
52 inch
Display Format
720p (HDTV) · 1080p (HDTV)
Digital TV Standard
HDTV
Projector Technology
D-ILA
Display Capabilities
Aspect Ratio
16:9
Built-in Tuner
NTSC · ATSC
Image Quality
Adjustable Color Temp.
With Adjustable Color Temperature
Technical Features
Picture in Picture
With PIP
Connectors
Rear Input Connectors
S-Video x 2 · Composite x 3 · Audio (RCA) x 3
Front Input Connectors
Composite x 1 · Audio (RCA) x 1 · S-Video x 1
JVC Contact Information
Main support number(800) 252-5722
Email supportproinfo@jvc.com
Describe your problem:
Top Projection... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
