I have a SONY Bravia XBR and the right side of the screen is dark. When it first started to happen,...
(More)
I have a SONY Bravia XBR and the right side of the screen is dark. When it first started to happen, it would eventually kick in but now it won't what is the problem and how do I fix it?
All HDMI inputs stopped working on my Sonay Bravia TV today. I bought the tv 6 months ago. Is there...
(More)
All HDMI inputs stopped working on my Sonay Bravia TV today. I bought the tv 6 months ago. Is there a easy fix?
I have had my Sony for six months. Last night I went to turn it on and nothing...it says no signal....
(More)
I have had my Sony for six months. Last night I went to turn it on and nothing...it says no signal. The Geek Squad told me to unplug, which I did with no result...still...no signal. When Charter installed my cable, there was no signal then either. The guys at the Reno store walked me through the initial set up an it did the trick. I don't know why it is not receiving a signal now. BTW, the cable on the TV in the other room is working. HELP! THanks. Patty
hello i have a sony bravia 46" set 1 year old and a sceintific atlantic 8300hd box from charter...
(More)
HELLO I HAVE A SONY BRAVIA 46" SET 1 YEAR OLD AND A SCEINTIFIC ATLANTIC 8300HD BOX FROM CHARTER WHEN I PLUG IN THE HDMI CABLE THE PICTURE IS GREAT FOR ABOUT 15 MINUTES THEN THE CABLE BOX KICKS OFF HAVE TO REBOOT IT THEN IT WORKS AGAIN FOR A SHORT TIME DO I HAVE THE WRONG KIND OF CABLE ??
vertical pastel color bars with gaps that some picture(ghosts) comes thru. can tell it on a channel,...
(More)
vertical pastel color bars with gaps that some picture(ghosts) comes thru. can tell it on a channel, but nothing viewable, no sound
sony 40" XBR LCD has dark spots on white background. Spots are in a oval circle about 8' in...
(More)
sony 40" XBR LCD has dark spots on white background. Spots are in a oval circle about 8' in diameter in the center of screen.
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked....
written by stiv0
Vizio Tv's have an extra menu that contains factory settings which you can change or fix should you have a problem with your TV.
Here's how to...
written by TechNerd
If an LCD TV has sound but no picture do the following: Use the source button to ensure that source is not set to the wrong input.
Try unplugging...
written by ginko
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal
is...
written by ginko
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the...
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After...
written by prowler21
When you have a damaged or unrepairable television it may seem like a total loss and ready for the trash. Instead of trashing the television, why not...
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's...
by wikihow
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
