HP DeskJet 3520 InkJet Printer Logo
Lewis Buckles Posted on Mar 23, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Clean printhead and breather hoses hp 3520
I purchased an hp 3520 at yard sale. black won't print but colors are great. put new black catridge in and still won't print black. how can i clean the print head and breather hoses.
Mohamed Hejazi
Level 2:
Filmmaker:
Uploaded 5 video answers.
  • HP Expert 196 Answers
  • Posted on Mar 24, 2013
Mohamed Hejazi
HP Expert
Level 2:
Filmmaker:
Answers
196
Questions
Helped
73827
Points
332
Try to reset the the black printhead , and clean the it
5 Related Answers
Anonymous
  • 159 Answers
  • Posted on Mar 15, 2010
SOURCE: HP Officejet Pro L7650 Print head problem
The reason why the printer refuses to print if you get low on one or more colors is that the system runs off negative pressure through the ink lines to the print head. If you were able to continue printing with an empty cartridge you could get air in the respective ink line, disrupt the negative pressure, make it so that that color will no longer print, and require you to get the printer serviced to fix the problem. I own a Cartridge World ink refilling store and I feel this is a good machine (compared to some of the others out there). The only down side with this type of machine is the print heads expiring or getting clogged as you are experiencing. The reason the black is clogged and not the other colors is that the black ink is pigment based and the colors are dye based. The pigment based inks do tend to clog print heads over time. You can try to rehydrate the print head with warm distilled water. if you can't get it working to your satisfaction you can buy a new black/yellow print head for $72. With this type of printer you should print at least one black and white and one color document per week to keep the print heads fresh. If they sit too long without ink flowing through them then they can get clogged and print poorly. I hope this helps belay some of the resentment you hold towards your printer.
Anonymous
  • 63 Answers
  • Posted on Oct 31, 2008
SOURCE: The following printhead(s) has a problem Black/Yellow[K/Y].
Simple solution is:
Replace the Black and Yellow Print Catridges. The print heads are mounted to the bottom of the catridges and these, depending on whther they're from HP or not. can have a hard time conducting electricity properly, and in turn.. spitting ink out properly.
Also happens often with aftermarket Catridges because HP puts chips on the catridge. be sure to put an HP catridge. Sometimes you get what you pay for :)
Anonymous
  • Posted on May 01, 2009
SOURCE: HP D135 - replaced printhead - still doesn't print in that color
try this link : I followed the directions and fixed the problem. the instructions that came with the new printhead weren't really complete.
Here's essentially all I did for my fix - Opened the printer top, turned the printer off. Removed the "bad" printhead, cleaned the metal contacts on the printhead and printer with windex. Closed the printer. Turned it on. waited for it to reset. Opened the printer. Turned the printer off again. Installed the printhead. Closed the lid. Plugged the printer in again. When it was ready I accessed the HP toolbox and alligned the printheads and cleaned the printheads. It worked. Here's a link with photos.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpa02107&lc=en&cc=ca&dlc=&product=64986
Rinoo Kumari
  • 2973 Answers
  • Posted on Aug 27, 2010
SOURCE: HP C6180 All-in-one the print
Peter,
Please un and re install the device drivers following the link below:-
http://www.fixya.com/support/r3559995-installing_devices_on_pcs_and_laptops
Ben Johnson
  • 686 Answers
  • Posted on Oct 21, 2010
SOURCE: My HP Officejet Pro K8600
Have you tried all these steps?
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02451504&cc=us&lc=en&dlc=en&product=3434447&tmp_track_link=ot_search
HP Officejet Pro L7555 will not print black ink
Replace print head(black & yellow) or try to clean the nozzle.(try youtube videos for cleaning)
HP photosmart B210 wont print black
Seems to be a common problem - I had it too. I spent a lot of time looking, but never quite found a consistent fix. I fixed mine in a few steps: First, I removed all the cartridges, and cleaned the filters on the top of the printhead (these are the little screens you see when you look at the tray with the cartridges removed). To do this I blotted each screen with premoistened alcohol wipes, changing wipes frequently, until the wipes were clean. I then removed the printhead by lifting the black handle on the right side, and lifting the printhead straight up. I used alcohol pads on the rear contacts (refer to HP's instructions for changing printheads) in a downward motion only. Finally, I cleaned
My hp photosmart 5514 won't print. I put in new ink-black and color- and it goes through the motions, but the page is empty
I just had this exact problem on my HP 5514. Black won't print after running out of black ink. New cartridge no good.
I tried everything-no good. I suspected the pinholes in the printhead were clogged with dried ink because I didn't change cartridge in time.
The fix that worked perfectly was when I hacksaw top off old black cartridge & removed all foam wicks so now I had a funnel(can see clear thru). I installed the cartridge & filled it with alcohol, printed page & did head clean; then printed few more pages. Problem cleared almost immediately. I then soaked up extra alcohol inside cartridge with paper towel. Removed modified cartridge & installed good one. I guess this could be done for colors as well. I don't know if this is a proper procedure, but it sure worked well for me.
HP 6940 won't print black-new cartridge installed-prints color but no black
In all likelihood your print head has become clogged at the black ink outlet. Be aware that printheads can BURN OUT if you keep trying to print and there's insufficient ink reaching the printhead. The ink flow is relied upon to prevent overheating of the tiny resistors at the printhead. Best bet is to remove the cartridges from the printhead and then remove the printhead and try to clean it in warm water. You will find many youtube videos on suggestions for cleaning the printheads on HP printers. Do a google search for your model. If all else fails you can order replacement printheads for the part that has failed. They are not cheap so price compare. Oftentimes they will cost nearly as much as a new printer!
I have a color printer hp office jet 7130 all in one and its only printing in cyan. is the printhead off? or broken can it be fixed and how much would it cost?
Go to paint create black,cyan,megenta & yellow images & print it, observe which colors are not printing,If back missed replace black cartrige, if any color missed out of remain three replace colour cartridge.There is no option to switch off the catridges & printer can recognise the faulty cartridge and it will show on displays.
You can order cartridges online.
2answers
I have an HP Photosmart C3180 printer color ink issue. Instead of printing yellow its printing pink. I've cleaned the head multiple times and the ink cartridge is brand new. Please advise. Thanks!
If what you're saying is still the result after cleaning everything up, there must already be something wrong with the printhead because the printheads are the one's that are responsible for the mixture of the ink cartridges.
Try calling HP Tech Support. They might still be able to replace the printheads for you.
Help w/ h/p deskjet 3520
hi/....
this is because of the low ink in the catridge. normally the colour catridge contains three colour in it. yellow ,blue and i think one more is pink. so in your case the other colours might have finished. so because of that you are getting only yellow. so please replace the catridge with new one and the problem wil be solved
I have an HP Officejet Pro 7580. When printing in
I think ur catridge must be empty plz fill ur catridge and then check
4helpful
2answers
Simple solution is:
k24674
Grand Canyon Tech
Grand Canyon Tech
