HP Officejet 7130 All-In-One InkJet Printer
Problems with HP Officejet 7130 All-In-One InkJet Printer?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
HP Officejet 7130 All-In-One InkJet...
Troubleshooting and Support
Solved Problems for HP Officejet 7130 All-In-One InkJet Printer RSS Feed
View More Results for HP Officejet 7130 All-In-One InkJet Printer
Questions and Unsolved Support Problems
Unsolved Problems for HP Officejet 7130 All-In-One InkJet Printer RSS Feed
Answer
I keep getting the following message on my HP 7130 Printer display: ?Scanner failure. Turn power off... (More)
Answer
i turn printer on and try to copy and then it comes on the screen scanner failure
Answer
My printer will not print, it keeps getting paper jam but I cannot find the jam. Also it is making... (More)
Answer
front panel displays "Scanner failure. Turn power off then on again" I have done so... (More)
Answer
I have done the cleannig and everything, but the famous error "scan failure turno off and on... (More)
Answer
the scanner failure keep on said turn power off and than on again hp officejet 7130 all in one what... (More)
Find a Manual
HP Officejet 7130 All-In-One InkJet Printer Manuals & Guides
WikiManual
(Post a New Chapter)
Inkjets and Laser Priners, Inks, Toners,...
Using recycled ink cartridges in your ink-jet printer is never a more economical way to do colour printing, unless you are willing to become a master... by Soulvisitor
How to Refill and Reuse a Printer Cartridge
Printer ink is one of the most expensive things that you'll run into when you set up your home office. You start out taking dozens of pictures with... by wikihow
How to Cut Printing Costs on Inkjet Color Printer
With all of the color printing that people do nowadays, its hard to find ways to print inexpensively. There are ways to reduce printing costs on... by wikihow
How to Check if Your Printer Has Run out of Ink
Have you ever wondered if your printer has run out of a colour? Here's a simple way to check. Steps: 1. Go into Microsoft Word. 2. Create four small... by wikihow
Lexmark All-in-One x3350
'Resetting' your Lexmark x3350 All-in-One So I tried using my Lexmark today... the power button is constantly on, and it won't do anything, My... by TTonyTigger
Upload Manuals
Tips & How To Guides for the HP Officejet 7130 All-In-One InkJet Printer
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
Canon PIXMA printer ink absorber full
if the printer shows ink absorber full on display you have to firsst physically acess the ink absorber pad then clean it up by removing the excesses... written by jonniewalker
Setting up a Shared Network Printer
Any printer that is connected to a computer and is connected on a LAN can be configured so all other computers on the same network can print to this... written by Geekman
How to remove the printhead of a kodak all in one printer
Open the top compartment of the printer, once you see the printhead dock to the center place your index finger on the "bullseye" sticker on... written by reitann
Ways to avoid getting clogged nozzles on your epson printers.
Three common ways that the printhead on Epson inkjet printers clog up. 1. Generic Ink is used. The problem with generic ink, is not only the chemical... written by SALES320
Black lines on faxes or copies
Do you have black lines in your scanned or copied documents? The typical problem is ink, correction fluid or trash blocking the image sensor. Look at... written by buddymc
How can I print what appears on the screen completely?
Many web designers are conscious of the fact that some people will want hard copies of their web pages. For these sites, you can... written by mianaftab
Printers and scanners and copiers (OH MY!)
How do I fix the error on my printer scanner copier fax that says "yada yada yada you cant print anymore"? 99% of the time, you cant. You... written by fredtmccoyjr
Setting up Epson Stylus SX515w on a PC.
This guide will show you how to setup the Epson Stylus SX515w, without using the setup CD & USB cable. 1) Using the Control... written by TJ4722
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for HP Officejet 7130 All-In-One InkJet Printer
Nationwide | 8008369287 | Website
Celebrating 14 Years Of Outstanding Printer Repair And... Read More
Featured Listing
Nationwide | 9185835483 | Website
Elite printer Services, Inc. is a full service HP & L... Read More
Featured Listing
Nationwide | 972-907-9771 | Website
Printronix, IBM, Tally, Genicom, TallyGenicom, Dig... Read More
Featured Listing
Nationwide | 800-786-0288 | Website
Accram is now one of the largest nation wide mai... Read More
Ratings for the
Find a Warranty
Warranty Information for HP Officejet 7130 All-In-One InkJet Printer
Specifications for HP Officejet 7130 All-In-One InkJet Printer
Key Features
Platform
PC, Mac
Type
All-in-One
Technology (Detailed)
Thermal Inkjet
Max Resolution (Color)
4800 x 1200 dpi
Black Print Speed
22 ppm
Output Type
Color Printer
Max Resolution (BW)
2400 x 1200 dpi
Color Print Speed
18 ppm
Technical Features
Form Factor
Stationary
Connectivity Technology
Cable
Duplex Printout
Standard
Monthly Duty Cycle
1,000 - 9,999 (Individual)
Monthly Duty Volume
5,000 Pages
Language Simulation
HP PCL 3 Enhanced
Memory Card Compatibility
Multimedia Card · Compact Flash Type I · Memory Stick · SmartMedia · Secure Digital (SD) · Compact Flash Type II
Direct Printing Capability
Print Photos Without a PC
Media
Media Type
Transparencies · Envelopes · Cards · Labels · Iron-On Transfers
Max Media Size
Legal (216 x 356 mm, 8.5 x 14")
Total Media Capacity
150 Sheets
Media Path Type
Curved
Multifunction Features
Copying Speed (Black)
22 ppm
Zoom Range, Enlargement
400 %
Zoom Range, Reduction
25 %
Copy Speed (Color)
18 ppm
Scanning Features
Scanner Type
Flatbed Scanner
Scanner Resolution
1200 x 4800 dpi
Faxing Features
Modem Type
Fax Modem
Fax Speed
33.6 Bps
Fax Features Supported
Delayed Faxing · Speed Dial · Color Fax · Scan Into Memory · Automatic redial · Auto Fax Reduction · Distinctive Ring
Networking
Networking Type
Network Adapter
Data Link Protocols
Ethernet
Memory
Installed RAM
32 MB
Max Memory
32 MB
System Requirements
Operating System
Apple MacOS 9 · Apple MacOS X · Microsoft Windows XP Home Edition · Microsoft Windows XP Professional · Microsoft Windows 98 SE · Microsoft Windows 98 · Microsoft Windows 2000 · Microsoft Windows ME
Warranty
Warranty
1 Year
Dimensions
Depth
16.3 in.
Height
13.3 In.
Width
21.9 in.
Weight
32.4 lb.
HP Contact Information
Main support number800-474-6836
Describe your problem:
Top Printer Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
