The belts spin and squeal during spin cycle. How do you adjust belt tension on this model?
It is normal for the belts on this model to be loose. Normally the noise that you are hearing is either the damper (a white plastic type material,comes in a kit) or the pump making the noise. Take the belt off the pump and put it into a spin cycle and see if you hear it. If so ck the tub bearing for rust or leaking and the damper for wear. If you don't here it, ck the pump.
SOURCE: loud squeal during wash and spin cycles, maytag atlantis washer
The belt is slipping and needs replaced.
SOURCE: Maytag Washer HAV2558AWW loud noise during spin cycle
Your maytag is really an amana and the bearings are bad. Yes it does cost a lot. If i were you i would buy another washer. Get a whirlpool. (whirlpool now owns maytag)
SOURCE: How to adjust new belt on maytag washing
sounds like you have a bad transmission. can you lift the top up so you can see what it is doing when it is trying to spin. does it adgetate and spin at the same time? If yes you have a bad transmission. also if you get 2 people one looking inside of the drum and the other turning the big pulley in one direction it should turn the whole drum in the other the agetator should go back and forth. Tell me what happens thanks.
