I ordered the EC and installed and the clock and timer work but if I try to turn on the oven or broiler I get an error message F4
any suggestions.I ordered the EC and installed and the clock and timer work but if I try to turn on the oven or broiler I get an error message F4
any suggestions.
the first ec was bad and when sears sent me the 2nd ec everything is working fine.the first ec was bad and when sears sent me the 2nd ec everything is working fine.
You can't post conmments that contain an email address.
Jun 23, 2007 - The error code "F7" will be displayed along with a beeping sound if the ERC (Electronic ... We have a GE Spectra Oven - GAS - we keep getting F7 errorcodes and the oven will not heat. ... In my case it was the keypad.
Apr 6, 2010 - Get shopping advice from experts, friends and the community! I was boiling water on back burner of ceramic stove top GE range Model ... When anyappliance picks up an error code or starts beeping the problem that caused it ...
I have the same problem. The burners work but not the oven. Ours started beeping with a FO code. The tech came out and said the control panel is bad and needs to be replaced. He also said ALOT of people are having the same problem and they might do some kind of recall down the road but for know we have to wait til Jan to get our part to fix it. Boo
the burners on ge range are different in size / you may have the caps on the wrong burners . 2nd / ck for the hole in the burner are clean ( do not enlarge them when cleaning .. ) if this does not work . see if the ignitor's are in good cond . if chipped replace .. mm
Hi I have a older GE that the oven won't light. It is a gas range that is electric ignited. The top burners do work but the oven will not light. Is it pricey to have this fixed?
Look in the back of the stove for a tech sheet. It should say on there. If I'm thinking of the right one, I believe it means the keypad is bad. Let me know what you find and I can help you further.
This is either a faulty display panel, or a short inside the oven that is causing the panel malfunctioning.
The wirings, elements (both), thermostat contacts inside the oven must be checked for an eventual short. If there is none, replace the control assembly.
similar problem after a power outage. Display would be blank until I turned ON an element (after which display would light, but no power to the respective element. No elements would heat even thought the dial shows power). Turning OFF the element would blank the display. I reseated the power cord and cycled the 50a basement breaker for 5 mins. Everything now works, but not sure for how long.
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
I will order the part and let you know.
Thanks.
any suggestions.
