When you try to ignite any burner, it sparks on the front left burner. Only the front left burner is...
(More)
When you try to ignite any burner, it sparks on the front left burner. Only the front left burner is working properly. Gas is coming out of the burner that your trying to light but the spark keeps coming out on the front left..
The digital display for a GE Profile stove model JGB900SEK-1SS is
showing an F9 error code &...
(More)
showing an F9 error code & another code. I read on a blog that
someone cleaned the contacts on the ribbon cable. I did that & it worked for a while but the code came back. Is it the push button circuit board
or the EC board that needs replaced? Can anyone tell me how to trouble
shoot this problem? The oven doesn't work at all when this code is on.
It worked fine when I cleared it temporarily. Help
we recently purchased a used GE JGB900 and everything works except the broiler/self clean feature....
(More)
we recently purchased a used GE JGB900 and everything works except the broiler/self clean feature. when you turn on the broiler it blows the gfi circuit. if you take it off of the gfi circuit, the ignitor will light but won't light the broiler, I think the valve won't open.
The digital display for a GE Profile stove model JGB900SEK-1SS is showing an F9 error code &...
(More)
The digital display for a GE Profile stove model JGB900SEK-1SS is showing an F9 error code & another code. I read on a blog that someone cleaned the contacts on the ribbon cable. I did that & it worked for a while but the code came back. Is it the push button circuit board or the EC board that needs replaced? Can anyone tell me how to trouble shoot this problem? The oven doesn't work at all when this code is on. It worked fine when I cleared it temporarily. Help
This advice is for GAS ovens with glow bar type
igniters. This is a fairly simple repair
that MOST do-it-yourselfers can accomplish with just a...
written by jsrock516
This advice is for Electric Ranges equipped with glass smooth tops. If it becomes necessary to replace the cook top due to wear or damage, here's some...
Here is a useful tip in identifying a frequently reported problem on some model ranges and wall ovens equipped with an Electronic Range Control (ERC)...
This "high end...?' range blew up twice early on when using the oven. My wife had her hair and eyebrows burned just by opening the oven door to...
written by skywagon185
As oven probes age, they can sometimes generate error codes on kitchen ranges and render them inoperative. The error code varies between models, but...
This advice is on how to replace a bad element on kitchen ranges that utilize ELECTRIC heating elements for baking and broiling. 1. UNPLUG the range...
Honest, Dependable, Available & Professional!
Appliance Parts Supply! We Ship Nationwide. Our Phones Answered From 7 AM - 9 PM CST Mon - Sat.
Over 30 Years Experience!
972-859-0929 - Call us NOW!
www.accurate-appliance-service.com
