GE Profile Spectra JGBP90 Gas Kitchen Range Logo
Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Center burner doesn't ignite all the way around
We have a GE Profile gas stove with the center burner (which has the removeable plate for pancakes, etc. The center burner will not light all around, only half of it will ignite. We've cleaned it, tried everything. It worked when we bought it. We bought it only about 14 months ago.
Posted by thewriteplac on
Anonymous
    New Friend:
I had this same problem. You will need to lift off the burner and remove the two 9/32" nuts and lock washers from the bottom of the center burner. Then separate the top section from the bottom. You will need to clean the inside of both sections down using a green scotchbrite pad removing and debris or small surface film the may have built up. Then rinse with warm water and dry them well. Reassemble it and your burner should work as good as new. Remember even just a small grease film on the burner holes will create this issue.
Posted on Feb 25, 2012
3 Related Answers
Anonymous
  • 13 Answers
SOURCE: GE Profile glass top stove. Large burner, only
had same problem with mine it was a bad burner a new one was 122.51 with tax. i tried the swich first and wasnt the problem. if you pull the burner out take a picture of the wires so you know where they go (theres 5) when you drop the burner you can see where the element is burnt. if the switch is the problem contact me aman2222000 @yahoo.com two 1/4 inch screws hold the top down if you open the oven you will see them and a phillips head screw driver takes the burner out. michael
Posted on Aug 22, 2009
Anonymous
SOURCE: Replacement Parts For Vintage Magic Chef stove
You probably have a 1940's model of Magic Chef. Check for the model number under the lid of the cook top on the upper right hand side of the stove. It should have the model number and the serial number, too. You will need both. The Old Applicance Club run by Jack Santoro is the place to go along with a site called "Antique gas stoves"in Georgia. Good luck with the world of vintage stoves.
Posted on Apr 06, 2009
Anonymous
  • 72 Answers
SOURCE: What is it??? How do u do it???
The button is a thermostat that measures the temperature of the pan, there's probably some cutesy name for the function, but it allows you to have more regulated heat on that burner.
Posted on Oct 20, 2007
8helpful
Our GE profile oven model JGsp31wet1ww oven will not heat up. When i set the oven to say 400 degrees, it just stays at 100 and never heats up. The broiler seems to work fine and the stove top gas burners...
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by amps.it takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
Need replacement drip pans for ge xl44 gas stove
u can find the parts only in the service center of GE appliance center.but if ur unit is more than 10 years,im sure no parts available.
All 4 ignators are spaking with the contrtols on off position on my GE JGP328 cook top
It's the Switch Harness. Do not remove the stove and disconnect it from the gas. Turn the gas off under the stove. Take off the: knobs and the plate; burners; hxw screws. Pull burners out and disconnect igniter burners. Lift the top of the oven off. The Switch Harness is on the right, under where the knobs are located. Replace the Switch Harnes.
Oven won't work on gas with electric ignition stove
The glow bar for the bake burner is bad, needs to be replaced. Remove oven bottom to get to it, and also the utility drawer.
3helpful
2answers
GE profile gas stove igniter don't stop igniting
take a look at the igniter located in the center of two burners. clean the gap with a stiff brush between the eletrode and the upper plate. the distance is preset at the factory. you may have enough buildup to close the gap enough to trigger the igniter.
2helpful
3answers
Ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
GE Spectra Range/Oven XL44
Resettle the small center tops on the burners. If even one is slightly off center or not level, a burner will not light, although it will click. Cost me a service call to learn this!
Open Questions:
See all GE Profile Spectra JGBP90 Gas Kitchen Range Questions
Top Kitchen Ranges Experts
Marvin
Marvin
Steve Sweetleaf
Steve Sweetleaf
Are you a Kitchen Range Expert? Answer questions, earn points and help others
