SOURCE: black screen with green smiley face
If your tv has a picture tube,your problem is in it. If you have only one line now,the vertical circuit is not working. You could have jarred something loose around the picture tube.Maybe a yoke lead ???
SOURCE: white horizontal line down middle of TV screen
caution whenever you see horizontal line please reduce brightness of your tv for safety of crt. your problem in vertical section only mostly due to loose contact in connector,print or loose components.
SOURCE: 1993 tube 37" mitsubishi
It looks like the vertical amplifier IC401 is defective. If you have soldering/desoldering skills you can change this part yourself. Also you may have to change C471 (.01UF 50V).
Good Luck.
SOURCE: flatline!
the vertical drive ic that drives the yoke for vertical sweep has blown.
sometimes it is solder problems like sharp and toshiba had.
the part is 10$ the pc board will label it ,the yoke is the coil setup on the picture tube.if you follow the wiring half goes to the horizontal drive,and the others to the vertical section.the chip drives the coil directly.there are VERY high voltages in there ,even turned off. the pix tube cap on top is 30000v. like a stun gun.the horizontal drive 2000 volts and the main power supply 165 volts dc high current.you need a special setup to discharge the picture tube.
