Dont know for sure where it is coming from other then the back.
There is a drain hole in the back/bottom of the freezer, check if the fridge is connected to a drain and water drains into the hole, looks as if it is cloged.that is a drain. Use a turkey baster with hot (not boiling) water to flush out the drain tube until water will flow out into the drain pan under the refrigerator. (where the air blown over it will cause it to evaporate)
hope this helps pls appreciate by rating as fixya.thanks and Godbless
There is probably a blockage in the drain over the pan. The accumulated
condensation backs up and falls out wherever. Look for the leads to the
drain and make sure they are clear, and unbroken. This may involve
lying the the fridge on its side
Do you have ice in the door?
