SOURCE: Power Led Flashing red 6 times....
the thermocoupler fuse is what it is called by the way. i also saw that it could be the "power board" which could or could not be synonymous with the thermocoupler. anyway, again it is a common problem with these models. Scott Jackson, MS
SOURCE: Sony KDF-E50A10 No Picture
4 times blink error shows that any FAN is not running in TV as there are 4 fans in this TV.
Please check fan connectors and make sure all are plugged securely.
SOURCE: KDF-E60A20 Red Light Flashing 6x
a 6x blinking error code is usually the thermal fuse located above the lamp housing on the light engine. probable cause of failure is clogged fan located in same area or poor ventilation because set is to close to wall [unit requires minimum of 4 inches of clearance]. part # is 1-910-023-93. another possibility but less likely is the gm board which drives the lamp voltage. part # is a1109407a.
SOURCE: we recently replaced the lamp on our tv and it
YOU NEED TO CHECK THE BALLAST AND AL 4 FANS, CHECK THE DOOR LAMP FIRST.
SOURCE: tv turns itself off after 2 minutes. the power
Hi...
Main power supply is overheating. Try getting it dusted out first then check into getting it serviced
