Question about Sony KDF-E50A10 50 in. LCD HDTV
The tv will turn on but no the screen wont. and
The tv will turn on but the the screen wont. and theirs a red light flashing where it says lamp on the bottom of the tv
Posted by albgirl13 on
Anonymous
    New Friend:
Turn on power kdf-e50a10 model standby light green flashes about 60 times or about a minute then red lamp light comes flashing continueously
Posted on Jul 08, 2011
electroman
    Genius:
  • Sony Master
  • 1,039 Answers
Replace the lamp would be the first thing to try. Lamp door switch on this model is notorious for going bad. If you replace lamp and still won't turn on jumper door switch. If you take off back you can see switch board.
Posted on Nov 21, 2009
Cooling fan, tv wont turn on
Inspect customer replaceable lamp first--lamp has a 2,000 hour life and may be bad---you getting any brightness on screen etc?
Apr 15, 2012 | Televison & Video
TV WONT COME ON AND THE LIGHT KEEPS FLASHIN RED AN GREEN ON THE STANDBY BUTTON
  1. If your Sony Wega will not turn on, the front green light blinks, you hear a faint whirring sound and the green light turns red and flashes, it probably means the lamp inside the set is no longer working. If you noticed the screen beginning to dim in the preceding days or weeks, this most likely is the cause.
  2. If the green light flashes and the picture comes on momentarily but then goes off, and the green button flashes until the set restarts, then the seal around the lamp mount is loose and needs to be refitted.
  3. If the picture on your Grand Wega cuts in and out and the green standby light flashes, both of the set's STKs need to be replaced. STKs are small chips on your television's circuit boards and are identifiable by their labels. The specific STKs used in your Grand Wega TV will be identifiable by the numbered labels on top of the STKs.
  4. When you plug in your Sony Wega and hear a loud popping sound, it's probably caused by a defect in the high-voltage circuit. Let the professionals take care of this one.
  5. If, after turning on your Sony Wega, you can hear your set but the screen is black, you most likely need to replace your projection lamp.
Read more: How to Troubleshoot a Sony Grand Wega ' eHow.com http://www.ehow.com/how_5243554_troubleshoot-sony-grand-wega.html#ixzz1EoY37gpC
Feb 23, 2011 | Sony Grand WEGA KF-42SX300 42" LCD TV
No matter what i do after replacing the bulb, the red lights still flash three times and turns off my tv, and when the new bulb was first installed the screen stayed very did and still said to change the...
Red light flashing means their is a problem with the Lamp or around the Lamp,Lamp Fan,Ballast board.
Encompass Parts Distribution visit there website for Parts/prices
1-800-638-3328
Mats has Lamps for $99.00 1-800-628-1118
It is possiable that the lamp you have has something wrong with it.
Oct 14, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Why does my tv turn on for a little bit but cant see the screen and a red light flashes
Tv red LED lights indication front of the bazel screen flashing are most common problems.When was the last time the projection lamp was replaced in this tv?The lamp in the tv now,is it in the the tv about 1 1/2 or 2 years and tv on watches about 4 or 5 hours a day in used?The projection lamp life are over.Require a new projection lamp.
Aug 03, 2010 | Sony Grand WEGA KF60XBR800 60" Rear...
I try to turn it on but it just blinks on stand by
Probable Lamp. If lamp hasn't bown the red Lamp Lite won't flash but other lamp issues cause stby timer light to continue flashing. If stby red lite is flashing, count the no. of times flashing - could open thermal fuse (6X flashing)
Nov 27, 2009 | Sony KDF-E42A10 42 in. LCD Television
After installing the XL-2400 Lamp unit. This is the blub and housing. I turned the TV on and after a few moments the tv turned off and on the front of the tv where the power light is it is flashing red.
Please make sure lamp cover is reinstalled securely after replacement of lamp in TV.
If lamp cover is not fixed properly, TV wont power up and red light will start blinking.
Jul 16, 2009 | Sony (XL-2400) Projector Lamp for...
Tv not turning on
I also have this model. A few months ago, when I turned on the tv, it told me my lamp was in need of replacement. just yesterday, my tv did the same as you....the blue light flashed and then the lamp light kept flickering. All I can say is your lamp needs to be replaced.
Mar 19, 2009 | JVC HD-56G657 Television
Sony bravia
what model of Sony is it? On many of the Sony projectors, a 3 flash error code indicates the lamp is not properly seated/installed or the lamp door is not closed properly
May 15, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony KDF-E50A10 50 in. LCD HDTV Logo
Top Sony Televison & Video Experts
Nasir Muhammad
Nasir Muhammad
Demonic-2011
Demonic-2011
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
