My washer fills with water, then it washes the clothes, and before is rinses everything stops. The water does not drain and I hear the washer trying to do something but nothing happens. What can I do????? Please help if you know the answer. :)
Hi sorintita65,the noise u hear is timer noise?its very common for the lid switch on your type of washer to break/fail.the lid switch is down in that little hole where the lid sits on the top of your washer.the lid switch is gray and it should be pressed up tight under neath that little hole.if you push in that hole with a pencil should hear a click.you will have to get anew part on line or at a local appliance shop.if you need more help you can email thru fixYa God bless ,tom
You probably have a clogged water pump you might check it out
Hello, i found that my lid switch is completely detached. How do you replace it. I am assuming we need to remove the top of the washer but i don't know how.
