Brandt WFH1276F Front Load Washer Logo
Posted on Jan 24, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where to put washing powder - Brandt WFH1276F Front Load Washer
Level 3:
  • Brandt Master 17,130 Answers
  • Posted on Jan 24, 2013
Brandt Master
Level 3:
Answers
17130
Questions
0
Helped
3635667
Points
52372
The detergent must go to the detergent tray
check this link: Detergent tray
There is caked washing powder let over in the tray after every wash and the clothes are not being washed properly. How do I fix this?
read the user manual for the right section to use
if you do not have a user manual then go google and type in ---user manual for ( make and model of machine ) and download a pdf version
personally washing detergent powder causes more problems that what it is worth
change over to liquid detergents
My washing machine won't use soap from the drawer
are you useing the right draw for main wash try putting on a wash and open the draw there should not be any water leaking if you do this and look in the compartment that you put the powder in and see if the water is going into the compartment that you use and see which compartment is filling thats the one to put the powder in
2 powder trays
Using powder in the pre-wash (open) tray is recommended for heavy loads but may not be required if the dishes get clean with powder in only the wash tray.
LAUNDRY SMELLS BAD
take out powder compartment its more likely its gone all black....also in side of the machine... get white vinager clean all inside and powder capartment .... put 2 ltrs of white vinager in drum place powder unit back were it should be..... turn machine on with no cloths in on full heat wash (boil wash)....wash through again with powder when finished ....twis before putting any cloths in ..there you have it ...oh check pump filter befor all this :)
9helpful
Do I put powder detergent in the same place I put Liquid detergent?
Detergent compartment
Add liquid or powdered detergent to this compartment for your
wash cycle. The detergent separator must always be in place,
either in the front or back position.
 Do not fill beyond the “MAX” level.
 Liquid or powdered color-safe bleach may be added to the
Main Wash compartment along with the same type of
detergent, liquid or powdered.
 Liquid detergent: Put the SEPARATOR in the front position,
between the guides, as shown as shown by Position 1 below.
There will be no gap between the bottom of the wash cycle detergent
compartment and the bottom of the separator.
Powdered detergent:
Put the SEPARATOR in the back
position, behind the guides as shown by Position 1 below. There will be
a gap between the bottom of the wash cycle detergent
NOTE: The separator will be in the POWDER (back) position
when shipped from the factory.
2helpful
Where ecxactly do you put washing powder and stasoft
Washing powder should go in the right hand side compartment, if it is not going down, then check that water is coming into washer.
Conditioner should go in the smallest of the compartments.
Please rate my solution.
Thanks.
Washing powder clogs up in drawer
There should be an adjustable "barrier" in the drawer. One for liquid and one for powder. Open the drawer and look at it carefully, you may need a flashlight. See where you pour the powder in? Well... you know what they say about pictures and a thousand words...
Since I don't have your model number, yours will probably look different than this pic,, but it should be close enough. All you have to do is set the barrier to the "Powder" setting.
SG
Put washing powder in tray ,machine doing wash but leaving large residue of powder
Don't put the powder in the tray. Select you wash cycle, let the water run into the washing machine, then add the powder.The powder should dissolve before you put your clothes inside the machine. Let the washing machine fill up to almost half way and add clothes. This should stop the clothes from getting the residue powder on it.
1helpful
Soap powder remains in the soap compartment
Depending on which compartment the powder is remaining in, it could be low water pressure causing the problem.
If it is taking some down, but not all the powder, then try putting the powder towards the front of the compartment.
If all else fails then I suggest you get one of these dispenser balls that you put straight in the drum with the washing.
Plz rate this solution.
thanks.
Top Brandt Washing Machines Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you a Brandt Washing Machine Expert? Answer questions, earn points and help others
