Canon MultiPASS F60 All-In-One InkJet Printer Logo
Posted on Jan 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Waste ink cartridge full
I have error message on my cannon multipass F60. So what do I do? Unplugging does not work or hitting the resume
Clive
Level 3:
  • Master 4,362 Answers
  • Posted on Feb 13, 2010
Clive
Master
Level 3:
Answers
4362
Questions
0
Helped
1814620
Points
14613
Maybe it waste ink
This works on the F30, F60, and F80.
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu-Copy-#
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [OK] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Skip step (6) since there is no [OK] key on F30 printers.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Problem message ink waste is full have lost manual how do I correct this
The waste ink absorber may be full, may not. But the message comes up on cannon printers after so many hours of use regardless. Just reset it.
STEP 1:- Disconnect printer from AC power
STEP 2:- Press and HOLD the POWER button, and connect printer to AC power
STEP 3:- release the the POWER button
STEP 4:- Press the POWER button again
1helpful
My MultiPass F60 Alarm light is blinking. It says "Check Printer/Press Resume". I have swabbed print head with alcohol to clean it. Could waste ink tank/reservoir be full. If so, where is it located and...
Fello there try
Waste ink nearly full LCD ERRoR on Cannon multipass F60 printer
HiHello try ths
6helpful
Canon MultiPass F60 "Waste ink near full"
Okay, follow these steps below to reset this message:
1) Enter SERVICE MODE. By pressing Menu-Copy-#
6) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Then call Canon 1-800-828-4040
Just inform them that you have already reset the counter so the error is gone, but you needed to know if there is a part that needs cleaned or replaced to prevent further problems.
Canon Multi pass F60 (waste tank near full)
Power off and on at button. If message continues it needs service.
Canon F60 Waste Ink reset
I had the same message "check printer. press resume key". I cleaned the encoder strip and reset the waste ink volume counter like 6 times and it helped. To reset the waste ink volume counter, follow the steps below. (These steps were originally posted by NerdRUs.):
2answers
WASTE INK NEAR FULL
I have the same problem and my power will not turn on if the resume button is depressed. Is there a way to fix the waste ink problem?
Alarm light on. F80
This worked for me on an F60 and someone else on an F30. Re: Check Printer error message on Canon MultiPass by watsonk (6/7/05 11:16 PM) reply + / - It could be due to "waste tank full" alarm; you may need to reset the waste tank counter. I found a reset sequence for a MP730 printer in this website that works for F30 as well. Try: Resetting the Waste Ink Volume Counter 1) Enter SERVICE MODE.--- By pressing Menu-Copy-# 2) Select TEST MODE. 3) Select [8] PRINTER TEST in TEST MODE. 4) Select 3. [EEPROM CLEAR]. 5) Select 0. [INK COUNT]. 6) Press the [OK] key. 7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key. Skip step (6) since there is no [OK] key on F30 printers.
Canon f60 print check
i cannot print alarm light is on window reads "waste ink near full"
old marine
old marine
ZJ Limited
ZJ Limited
