Refilled Ink cartridge but the printer says there is no Ink
I recently refilled the black in cartridge for the 2nd time. I have put it back in the printer correctly but everytime I try to print it says there isnt any black ink and cant print!!!??? anyone have any idea?? it's driving me up the wall!!!
Re: Refilled Ink cartridge but the printer says there is...
You refilled or purchased a new cartridge? If you refilled ; did you do it after the printer told you it was out? The cartridge electricial would have to be reset. How to do that is a guarded secret for Canon. Buy a Canon One and replace Cartridge, would one on solution.
I would never use refilled ink. This is a lesson. You can still print, yet the cartridge needs a new "chip" they should have given you when they refilled it. You can try: remove the cart. turn off printer, unplug it, then put old cart back in. Do this three or four times and the memory of the printer can only remember three or four resets and then put refilled cart in. Hope this works for you. I was told this for an HP 7130 (similar, yet older version).
Brock
Ink level counter (program) didn't read actually ink at ink tank. Brand new cartridge ink level counter 100% (full), and ink 100% (about 10 ml). After may printing, ink will dry out, and ink level counter reach zero (ink out). Printer will not allow print anymore, even have refilled, because ink level read "ink out". For canon type, you just to release ink level counter, and counter just stop, but printer will allow to print. Press stop/reset button for about 30 second.
I suspect that your have a damaged refilled cartridge. Also, you may have a clogged nozzle. Canon printers are sensitive to the quality of the ink used in the cartridges and refill ink sometimes does not meet the manufacturer's specifications. You can check this by inserting a new OEM cartridge, running the deep cleaning utillity three times and a aligning the printhead. The other problem may be that the electronic chip on the refilled cartridge may either be damaged or blocked by dried ink. In any case, you need to discard the failing cartridge and replace it.
Let me know if this solves the problem. Thanks.
the problem with the refilled ink is that the ink is NO WHERE near as good as the original HP ink and the ink cartridge is now damaged - just replace the cartridge with a new HP cartridge and you should be OK!
Hello! 28 and 29 are not meant to be refilled. They can physically be refilled, but they won't work. That is because Lexmark has put in a smart chip that doesn't allow refill. You need to buy 28A and 29A or 34 and 35, those cartridges can be refilled with no problem.
If you find my answer helpful, please vote. Thank you!
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
I've refilled cartridges twice so far. The first time, the black was completely empty and the color was nearly empty. The printer accepted the color refill and not the black. The second time, I refilled both cartridges before they completely ran dry and both were accepted by the printer. The gauges don't register the ink, but it prints just fine. I just monitor the levels through the print quality. A friend with the same printer has told me that she only get 2 - 3 refills before the cartridge has to be reset, and that is a tricky process, but can be done.
Sometimes refilling them over and over doesn't work well. Once ok...but i suggest that you buy a new cartridge. I know that they are expensive but it will help. Also take some Rubbing alchohol and a q-tip...clean inside where the cartridge sits..that will help...this is for sure a bad ink cartridge
