If you found oil underneath it, then you have a broken transmission case, or a bad seal. The electric motor does not contain oil. This should be something that yuo can confirm visually.
quick question everyone. I dissassembled the machine. There is a plastic piece between the motor and the transmission that is broken. Could this be my whole problem?
I doubt that this would cause the oil to leak, more likely that the plastic broke because the gears are unable to move freely. Try pushing/pulling on the plastic linkage that remains and see how it feels. I think it will be stuck, which points to the transmission being siezed and the plastic linkage breaking as a result.
SOURCE: loud noise while agitating in wash cycle
If you begin dissassembly from the tub down, you wil come to the transmission with the spindle sticking out of it. If you undo the bendable tabs all around the transmission it comes apart in two halves. Careful, its full of oil. The spindle has a plastic gear bolted to the bottom of it. It meshes with other gears in the tranny. It has sheered teath and is making the noise.
SOURCE: washer won't drain, makes loud noise
This problem, or some variation thereof evidently is very common with these Whirlpool Washers! I have same problem. So far, best I have found is at
http://applianceguru.com/forum2/5958.html#
diagnosis by someone who knows. What William Burk says there makes sense. However, to get to the drive block there's quite a bit of disassembly required. I am stopped because I cannot get the spanner nut off. Hope this gives you some help toward finding a more comprehensive answer
SOURCE: Whirlpool Washer making loud noise during agitation. Agitator appears to be very loose
Does anyone have the name or part number of the piece that needed to be replaced that help stop makes all that noise?
SOURCE: kitchenaid top load washer wont agitate or spin
you have a direct drive washer with a coupling broke.Here is a good article on it http://repair2000.com/coupling.html
SOURCE: Whirlpool washer agitates but makes a very loud noise
It sounds like the agitator teeth, that are plastic, are worn out. To check this, take the agitator cap off with a strong knife or flat-head screw driver, and check the circular teeth inside, to see if they are worn out. These plastic teeth are the agitator part of the washer, where as the spinning part is a metal set of teeth, at the bottom of the agitator. You see the metal teeth, when you take the agitator completely out. You will have to replace the agitator if the teeth are worn out.
