If you are given print command and that time printer off position no issue, because print command given after on the printer then printer seance any command or printer print the doc.
Disconnect the USB cable from the back of the printer. Uninstall the software of this printer. Then after uninstalling it now re-start the computer. After your computer starts completely then just connect the USB cable from your computer to your printer and windows 7 will install basic drivers for your printer, print a page and it will print the documents.
If I understand you question correctly:- go to "printers and faxes" in the Control Panel, select your printer, highlight the command printing your job and click on 'Document' 'Cancel'. it takes a little while to stop printing. Otherwise check your printer documentation, there may be an instruction like holding down the 'on' switch for five seconds to clear the printer instructions.
Dear user,
Your printer already have many commands given for print. that why is prints all that data which is already have given.
To clean the print commands. open your printer from Control panel---> printer and faxes--->> your printer
and then cancel all the commands which are waiting to be print.
You will not have anymore unwanted prints.
sir reinstall your printer software and drivers or follow my commands go in your start>printers and faxes>and right click on your printer>properties>ports and select your port and apply
If you are using one printer in the same office, i mean if all the other employers also using it than this problem arises. Because if many employers using it than printer will always print in order of the print commands given. It works as prints given in order by time. If this is not the case than you can try to delete old print commands by switching the printer off and than deleting. I think this must help you.
If my advice helps you please feel free to rate me thanks.
