? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I demonstrate in this video how to repair a Sanyo by swap out the... the Sanyo DP47460 that I'm having an issue with. after ~ 40minutes of watching, if I attempt to change the channel or adjust the volume, the picture/screen freezes. ... After ~ 20 seconds, theTV will automatically shut off, then turn back on.
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Hi, I've got a Samsung LED TV that switches off after20 seconds and remains off. .... after about couple of minutes, is this the same problem with the tv in the video? .... 10:32. How to repair a Samsung LCD TV with a flashing standby ...
It sounds as if you are having problems with the AC Power reaching the television. Please verify the cord is firmly seated the tv's ac inlet
Also check the wall outlet (and power strip) by plugging in a lamp into it and see if it flickers when the tv shuts off.
Good Luck!
Rich Lilja
When tv it shutting itself off by it own does the tv power LED light indication flashes?Tv turn on now,the tv power light indication,just flashes?Yes,than ur tv power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
This is an on-going problem with DLP sets. Normally you shut the set off and the cooling fan cools the lamp down and then it shuts off. In your case, of which it's not your fault, however your lamp has taken a major hit by not properly cooling down, in turn, you need to replace your lamp at this time.
I suggest in the future if you have an electrical storm and a chance of a power outage while your watching tv, I would'nt play that model or any other model of a DLP set.
Your TV is overheating.. easiest remedy is to point a fan at the back of the TV or... clean the inside of the TV, Im sure its full of dust and stuff... this prevents air circulation inside the TV thus creating more heat...
