i just bought a sanyo 50in. plasma tv and when i connected it wouldnt turn on. I want to know if i...
(More)
i just bought a sanyo 50in. plasma tv and when i connected it wouldnt turn on. I want to know if i have to do something specific to turn it on or it just donst work
Will not power on, no power light, no picture and no sound. Set was working fine then just powered...
(More)
Will not power on, no power light, no picture and no sound. Set was working fine then just powered down. It was unplugged for a while then I tried again. Still nothing. I know I have power coming through power cord to unit. There were no previous problems with this unit.
My tv turned off after watching for 5 min. Wont turn back on. I replaced 5 fuses but nothing...
(More)
My tv turned off after watching for 5 min. Wont turn back on. I replaced 5 fuses but nothing happened. Whats wrong?
i have a dp50747 50 in" sanyo plasma .The picture went out and sound. I took the back off and...
(More)
i have a dp50747 50 in" sanyo plasma .The picture went out and sound. I took the back off and the psu fault light comes back vamp ovp.
I have a Sanyo 50" Plasma and we heard a loud pop just before and now there are black blobs on...
(More)
I have a Sanyo 50" Plasma and we heard a loud pop just before and now there are black blobs on the right and left side only goes 3/4 of the way up the screen and 1/4 way in
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked....
written by stiv0
Vizio Tv's have an extra menu that contains factory settings which you can change or fix should you have a problem with your TV.
Here's how to...
written by TechNerd
If an LCD TV has sound but no picture do the following: Use the source button to ensure that source is not set to the wrong input.
Try unplugging...
written by ginko
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal
is...
written by ginko
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the...
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After...
written by prowler21
When you have a damaged or unrepairable television it may seem like a total loss and ready for the trash. Instead of trashing the television, why not...
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's...
by wikihow
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
