Just bought this from individual on ebay to replace the 720 i have (backlight stays on and battery dies). When i received it the display reads 'safe mode 157a'. If i plug into computer via usb it flashes the safe mode code. i've removed battery and installed fully charged battery but same result. When i try to change remote or update firmware its stuck in sleep?
SOURCE: logitech harmony advanced universal remote 550 display safe mode
remove the batteries from the remote
hold down to the number 2 key
as you are holding down to the number 2 key (do not let go of this number key) put the batteries back in
now remove the batteries again and put it back in again without pressing any buttons
if this does nto fix the issue
do a firmware upgrade
SOURCE: My Harmony 550 remote is stuck in safe mode. What
Hey!
I thought this link might help get your Harmony 550 working again:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=11941
Hope this helps!!!
-Kennedy
SOURCE: Have blank screen, but remote works. Harmony 890
If the screen is still blank after you update the firmware in safe mode, then it is a hardware issue and you should contact Logitech's wonderful support team, given that the remote is still under warranty.
Hope that helps :)
SOURCE: Frozen Harmony 550
Hi. You will need to update the firmware.
1. In the software, click "Downloads"
2. Click on "Firmware."
3. Update the remote
That should fix it!
SOURCE: 520 remote is locked in safe mode...tried
Hi There,
One solution I have found online for getting the 520 out of safe mode is to follow these steps:
1. Remove the batteries.
2. Hold the '2' button down on the remote.
3. Whilst still holding the '2' button down, replace the batteries.
4. The remote should now boot in normal mode.
Please note, If the 'off' button is held down whilst inserting the batteries the remote starts up into safe mode.
Hope this helps,
James
