Tip & How-To about Televison & Video
Logitech Harmony Safe Mode Fix
Is your Logitech Harmony Remote stuck in SAFE MODE?
If you upgrade / update the firmware of your Logitech Harmony Remote, your remote will no longer be in SAFE MODE.
To upgrade or reapply the firmware on your Harmony remote:
  1. Launch the Harmony remote software and log into your account.
  2. Click on the Downloads button at the top-right corner of your screen.
  3. Click on the Firmware button. Follow the onscreen instructions to upgrade the firmware on your Harmony remote.
  4. Once the firmware upgrade is complete, click on the Update Remote button.
Your Logitech Harmony has now had its firmware updated, and is no longer stuck in SAFE MODE.
I hope that helps.
____________________________________________
Logitech Harmony Firmware Update
Televison & Video Logo
what is "Safe Mode?and how do I get this off my remote? It is completely not working. The Activities button is light up and it simply says Harmony Safe Mode.
1. Remove the batteries. While holding the 2 button down, connect the USB cable. The remote will boot into normal mode.
2. Update the firmware. Update the configuration. If you are unsure of how to do this, please see below.
- Upgrading/Reapplying the firmware on your Harmony Remote
- http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=10747
3. There could be a stuck button on the remote causing the symptom. Remove the batteries from the remote. Push in, and massage each button ensuring it is not stuck down. Replace the batteries and Update the firmware. Update the configuration (update the remote).
4. Remove the batteries from the remote. Manually place the remote into `Safe Mode` by holding off and plug in the USB. Upgrade the firmware in the remote. Update the configuration (Update your Harmony remote).
May 06, 2010 | Logitech Harmony 520 LCD Remote Control
Logitech Harmony 670 remote stuck on Safe Mode. How do I get out?
1. Remove the batteries. While holding the 2 button down, connect the USB cable. The remote will boot into normal mode. Did this fix the problem? If no, please continue to troubleshoot.
ANSWER:
2. Update the firmware. Update the configuration. Did this fix the problem? If no, please continue to troubleshoot.
ANSWER:
3. There could be a stuck button on the remote causing the symptom. Remove the batteries from the remote. Push in, and massage each button ensuring it is not stuck down. Replace the batteries and Update the firmware. Update the configuration. Did this fix the problem? If no, please continue to troubleshoot.
ANSWER:
4. Remove the batteries from the remote. Manually place the remote into `Safe Mode` by holding off and plug in the USB. Upgrade the firmware in the remote. Update the configuration. Did this fix the problem? If no, please e-mail us back for further information about your issue.
ANSWER:
FIRMWARE:
1. Log into the Logitech Harmony Remote Software on your computer
5. Test your remote.
Jan 31, 2010 | Logitech Harmony 670 LCD Remote Control
stuck in safe mode
FIRMWARE:
Jan 27, 2010 | Logitech Harmony 520 LCD Remote Control
it says safe mode
Hey!
I got my Harmony Remote stuck in safe mode and found the following link that got it working properly!!!
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=11941
I hope this helps!!!
-Kennedy
Aug 05, 2009 | Logitech Harmony 550 Remote Control
2,489 people viewed this tip
Top Televison & Video Experts
