Hitachi 53UWX10B 53" Rear Projection Television Logo
Posted on Jan 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Projection TV is out of focus
Had no problems with this TV, always had a great picture! One evening we turned it on and it was out of focus. We hadn't made any changes to the TV. It hasn't been moved, no changes. We tried the MAGIC FOCUS button, didn't help. We would like to fix this ourselves.
  • 1 more comment
  • Anonymous Mar 07, 2009
    the colors aren't in sink anymore, it's like watching a 3-D movie without having 3-D glasses.
  • Anonymous Mar 11, 2009
    I have the same problem. I had the amplifiers and resistors replaced. Worked ok for about 2 days and went bad again. Repairman said I needed that whole assembly replaced. He tried to find one and couldn't. Any ideas to try
    Thanks
    Jake
  • Anonymous May 04, 2009
    Same problem with my SONY rear projection TV (50").
Anonymous
Level 1:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Jun 29, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
0
Helped
18941
Points
6
CRT coolant change and advanced convergence - how to
I documented the procedure I did on a Philips 55" rear projection 55p916
http://tinyurl.com/lmp6eu
CRT coolant change procedure
http://tinyurl.com/l7bd7r
basic and advanced convergence
Anonymous
Level 3:
  • Hitachi Master 3,459 Answers
  • Posted on Mar 09, 2009
Anonymous
Hitachi Master
Level 3:
Answers
3459
Questions
5
Helped
850002
Points
5558
Solution #1 posted on Feb 28, 2009 Projection TV is out of focus - 0%20stars_w.png
19a7683.gif Ecollier2012Rank:guru_s.gif Guru
Rating: 91%, 106 votes
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu. Screen is bowed or warped.
  • Projection TV is out of focus - 77ea520.jpgrc="/uploads/images/701cb04.jpg" altProjection TV is out of focus - f0900cb.jpgpg" class="h_mi" />
    Here is a quick test....
    Using your original remote go-to the tv settings then goto the convergence section.
    Try to adjust the red and then the blue convergence.
    You should be able to move them up, down, left, and righProjection TV is out of focus - 2c07611.png />If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
    2c07611.pngSolution #1
    You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
    Problem #2 CRT Fluid is Cloudy
    Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see haloProjection TV is out of focus - 578ba6c.jpgages.
    Picture of a set that needs the fluid changed.
    TV set after fluid change
    2c07611.pngSolution #2
    What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Anonymous
Level 3:
Genius:
  • Master 1,139 Answers
  • Posted on Jan 19, 2009
Anonymous
Master
Level 3:
Genius:
Answers
1139
Questions
Helped
413602
Points
2179
Hello hocusfocus,
I posted this before, but it fits your problem too, so here goes:
You have a convergence amplifier problem. This is a common problem in these types of televisions. The fix for this problem is to replace the two convergence amplifiers in your tv. These amplifiers usually go bad along with the associated bias resistors. I would suggest that if you are going to do this yourself you should use only the manufacture recommended replacement parts. There are many who will tell you to upgrade the amplifiers, but my experiences have told me this is more trouble then it is worth, if you don't plan on redesigning the circuit itself. So with that being said, here is the basic procedure:
1) Get a schematic for your set (to be used in parts location and alignment instruction)
2) Using the Schematic locate the STK329-xxx or STK392-xxx series amplifiers (They are the two large six sided components attached to a large heat sink on the deflection board)
3) unplug the TV set
4) remove the deflection board from the TV set
5) using a soldering gun or iron with either a de-soldering pump or de-soldering braid remove the solder from the pins of the amplifiers and the associative biasing resistors.
6) remove the amplifiers from the heat sink and clean the heat sink off with alcohol or a solvent designed for removing the silicon paste.
7) coat the metal plate of the new amplifiers with heat sink paste and install them on to the heat sink.
8) install the associative biasing resistors
9) solder all of the components, making sure not to create solder bridges (short circuits) on the printed circuit board.
10) inspect the soldering job for bridges and cold solder joints (touching the joins up if they are cold)
11) reinstall the board to the television (reconnecting all cables removed.
12) power up the TV and perform the alignment instructions in the schematic
13) set the alignment of the TV
14) perform the magic focus setup
This should complete this task.
Now if you feel that you can not do these tasks, please consult a qualified TV technician about doing this for you.
I hope this helps
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Flash focus can no longer line up all colors,and gren is the one always sticking out;do I need to replace all my "color lamps"?
No,this tv have no projection lamp,tv only have 3 CRTS tubes guns R,G,B.Ur tv have a problems known convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike.The tv convergence board is dead.Tv convergence board,must be replace 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
1helpful
Sony kp-57hw40 double picture. regular and the other right next to it is red. tried auto focus and nothing happens. while holding auto focus btton down get red cross and white next to it. tv is 9 years...
Auto Focus button no longer work.Tv have a problems known as a convergence problems,it dead.Tv have colors lnes R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts,must be replaced on the tv convergnce board to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
I have a Hitachi Projection TV 51G500A 2004 ,
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
I purchased a tv repair kit and replaced the convergence ic chips to fix my convergence problem. put everything back together and now, no picture. I tried magic focus and it works great, the colors are...
As per statement, "the magic focus works great, the colors are bright and aligned" it means the tubes are working ..you need feed a signal to see the picture...the tv video goes muted without signal
1helpful
Sony rear projection tv model KP-53V15 turns on, have sound but no picture, after a while, picture comes on, but later goes out again, picture keeps coming and going. Where do I start looking?
Adjust Screen Volts (G2) of all 3 picture tubes and screen volt control knobs are on focus block located under speaker grills at front of TV.
Remove speaker front grille of TV, look for focus block that has 6 control knobs, 3 knobs are for focus and 3 for screen volts, increase volts by turning little bit control knobs of screen volts and this will solve your problem.
Rca mm52110 rear projection tv with issues
Will power up, but won't have a picture. What could cause this?
1986 tv won't turn on
Great TV you bought.
At this point I would say it might not even be worthy to get the TV fix due to the age unless you can do it yourself.
In my opinion you can save the money from the repair to buy a new TV.
Hope you do not upset with the messenger LOL.
3-D picture
Good Day, ladyluck5509;
It sounds like the TV is experiencing an auto focus problem. That in other words is a convergence problem, needing to replace the convergence IC's, chips. There is no known focus knob. If you are concern of shocking oneself, I would recommend that you seek a factory authorized service center for repair. Always, always get an estimate first.The normal/average cost for this repair should run between $350.00-450.00.
Good Luck, Big Irish.
Picture goes black
With a shop doing the repair they will almost always say the deflection PCB will need to be replaced which would be about 350.00 plus labor. I would suggest trying to solder the vertical output IC first as that is usually the cause on the mitsubishi rear projection or solder around the flyback one of the two.
P56930BL focus problem
Sounds like you need a new focus block, they are actually cheap. If you need a link on where to get one let me know.
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
