SOURCE: Frigidaire washer will not start. Get err and LOC codes.
All the lights are on, but the door lock. We have unplugged it, doesn't help. Our washer is the front load, model LTF 2140ES0.
SOURCE: help with whirlpool awm 8103/1
Okay, ther manufacturer recommends unplugging the washer for at least 30 minutes to reset the computer. It could be you have a momentary glitch causing some problems. If you still have the same problem after leaving the washer unplugged, the following link explains the "FH" error code:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
If your clothes are stuck inside and you still cannot get them out because the door will not unlock, you will have to use the manual release to open the door. The next link explains how:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
I hope this helps you. If you require additional assistance, please let me know.
SOURCE: Door Lock LED flashing
The solution from testy helped me but I decided to change it.
I cut the plastic latch away from the end of the interlock,just the little bar that holds the door closed.This means that the lock position doesn't affect the door.
I then used the little piece of plastic to act as 2 packing pieces to hold the lock half closed. This works fine.
Don't push the lock fully closed or it doesn't work
SOURCE: Hotpoint WF860 Washing Machine displaying error F-65
there is no F65, perhaps it's F05 which means it will not empty water (not oumping out). Should av gone to specsavers !
SOURCE: Every time we try to wash it comes up test and
Try the following, may work:
