Question about Hotpoint Ultima WF860 Front Load Washer
I have a Hotpoint Ultima 1200 - WM75. At the end
I have a Hotpoint Ultima 1200 - WM75. At the end of a wash cycle and at the start of the rinse/spin cycle I get an Error message indicating blocked outlet pipes. I checked the drain hose and the waste pipe and it was clogged up. I have now cleared the blockage but I still get the error message - any thoughts what could still be blocked??
  • John Denneny Oct 24, 2012
    I have the exact same problem. Once I had removed the gravel filling up the filter just before the pump the water was pumping out like a fire hose instead of a dribble. I would have bet money that the job was fixed so I put everything back together and was amazed to see error E15 following a complete emptying of the drum. It seems the machine thanks there's still water in the drum even though there clearly isn't. I removed the pressure switch at the top of the machine after disconnecting the clear plastic tube and blew down the pipe while connecting a mutrimester and it seems to work fine. So I'm now at the point of choosing between a faulty controller or simply the pressure needed in the pipe to activate the switch lust isn't there. Any help very much appreciated.
  • Hotpoint Master
  • 3,463 Answers
Check the filter and the actual pump itself for blockage.unless you have already done so, also pump itself could be faulty.
Posted on Mar 29, 2010
6ya staff
SOURCE:
F-04 on hotpoint ultima can you tell what this means please
"F04" on the display panel before the programme ends. Have you cleaned the filter out on the pump
Apr 06, 2013 | Hotpoint Washing Machines
In my hotpoint ultima WMD942P washing machine's softner compartment i always find water at the end of the cycle. its a new machine.
This is completely normal, the machine puts water into this chamber during the rinse cycle to wash the softener into the machine.
Mar 05, 2012 | Hotpoint Washing Machines
Hotpoint Model WM75 Error Code E30 (Motor Drive problem)
what does e30 mean on wm75 hotpoint ultima 1200
Dec 02, 2010 | Hotpoint Washing Machines
My Hotpoint Ultima keeps displaying an F10 fault and doesnt spin correctly. However, if I then switch it to a rinse and spin cycle it seems to spin OK.
F10 meanswater level pressure switch not sensing correctly, there could be a blockage in the switch hose or chamber, or the switch could be faulty.
Jan 17, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WF860 Cycle does not end
could b presure system blocked up find this on side of filter long plastic *****
Nov 29, 2009 | Hotpoint Ultima WF860 Front Load Washer
Will complete wash/rinse cycle, start spin and pump out but not speed up
put a full load in it, its telling you that, try 20 shirts, or 10 towels
May 27, 2009 | Hotpoint Ultima WF860 Front Load Washer
My hotpoint ultima super silent displays 'test' but dnt run cycle
its in factory test mode, this can be set by pressing the on and start buttons together. to reset, turn on while pressing the on and start together until dOFF appears
Jan 25, 2009 | Hotpoint Ultima WF860 Front Load Washer
Ultima WF840 won't go from wash to rinse cycle
the pump is blocked, so the sensor detects that the machine has not emptied in the allocated time, so this will reset the time.... the pause is because it knows there is a probblem getting rid of water.
location: bottom right near the motor. ensure you tip the washer as far forward as you can so you can get a bucket under in order to prevent flooding.
hope this helps
Aug 17, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Knocking noise on spin cycle
My machine did the same thing, I found it to be the heater element in the air box had come loose inside the casing and was hitting the sides of the air box. Removed air box from machine and resecured the element now all ok
Apr 10, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
425 people viewed this question
Top Hotpoint Washing Machines Experts
Eric Taylor
Richard C Cohen
Richard C Cohen
Onofrio Taverna
Onofrio Taverna
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
