You put a 3/8" ratchet in the tensioner arm. Looking at the side of the engine to the passenger side of the van, the tensioner is at the top of the engine towards the back. Twist the tensioner to allow the old belt to be removed, Install the new belt following the same path. There should be a sticker on the belt guard by the power steering pump. The belt will fit smoothly on all the pulleys. Pay attentions as some pulleys have the belt groves facing in, some have the belt groves facing out.
IMPORTANT - When you do this, put all the keys for the car in your pocket so no one can try to start it.
1999 no car body or model car stated so NO JOY, nor country.
generic answer.
same as all cars.
find the pulleys effected, look at each, 1 has an adjuster.
loosen it, put on belt and set tension to spec.
end.
You need to purchase a Haynes Manual or better. They are very common in your nearest chain part store. Like Autozone, Advance, Napa. More than likely you will have to set the crankshaft at TDC. "top dead center" and allign the two marks with the cam shaft! Watch when you put tension on the belt it will move the camshaft sprocket! And throw it back out of time.
The 2.4L four has a belt and is not an interference engine according to the Gates timing belt application chart for your vehicle (check it out on Gates.com.) The 2.7L V-6 doesn't show that it needs a belt--so it has either a timing chain and gears or just gears. If the belt broke on the 2.4L four, you should be able to put on a new belt and go. The engine should not be damaged.
If the timing chain on the V-6 broke then engine damage may have occurred. Chain engines are sometimes not listed as interference because breaking a chain is so rare. The damage would probably be bent valves and damaged piston tops. The labor involved in repairing all that might cost more than just getting a rebuilt engine and putting it in.
The only ways that I know of is to either take apart the valves and check them, or put in the new timing belt and start it up and listen to the valve train. If the timing belt broke under power there is a good chance of valve damage.
