Linksys Wireless-G WRT54G Router Logo
Posted on Jan 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Limited connectivity I recently connected a router to my computer. I will be able to connect to the internet for a couple of hours then i lose connection on both my laptop and desktop. desk top says it can't find the server and the laptop has a strong signal from laptop to router but no internet. if i reinstall the router then i get a connection on both again for a limited time. I think the problem is between my router and desktop. I have AVG antivirus and the router is set up for WPA personal and my laptop has Norton. Any advise would be helpful.
Anonymous
Level 3:
Genius:
  • Master 1,913 Answers
  • Posted on Jan 01, 2009
Anonymous
Master
Level 3:
Genius:
Answers
1913
Questions
5
Helped
687911
Points
5322
Check your ip adreses
it is range of router
Connected to WiFi but cannot connect to internet. Many other devices working fine on the WiFi. Reset phone and router. Still no luck.
Will your phone connect to internet through a router anyplace else? If it will then it's possible maybe that the settings in you router have limited how many devices can connect at one time. Maybe try disconnecting a couple of the other devices long enough to see if your phone will connect to the internet through your router then. If so you can Google the address for your router the connect VIA hard wire to your router go to it's page and maybe change a setting that will allow for more devices to connect through it! Thank you, hope this helps.
I lose connection even when hardwired
might need a firmware update check website for recent and compare to firmware on your modem
I have Belkin F5D7234-4-H V5 Router and I have one computer connected by cable and laptop connected by wireless. Computer on cable have constantly connection to the internet, but time to time laptop losing...
Go to http://setuprouter.com/router/belkin/f5d7234-4v5/login.htm and then follow the instructions following: Login to the Belkin F5D7234-4v5 Router and work your way down through the instructions.
No connection, cant install the software
You said that when you connect the computer to the modem, you get limited or no connectivity. make sure that your computer will be able to go online when you connect it the modem directly.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Spontaniously lose internet connection to status "limited or no connectivity" intermittently and have to reset and reconfigure. this can be after 1 hour of use or several days
We have solved our wireless connection loss by connecting the Hawkings by cable to the first computer needing a signal from it a second computer is able to connect to it OK, these two computers are upstairs and the main computer with router is downstairs this is working OK at the moment without the frustration of losing the internet connection
Your router may be configured to "connect on demand". Enable the setting called something like "Keep Alive"
GotomyPC Intermittent connection
had same prob. 3 wired an 1 wireless . wireless would not conn. an others lose connection . after cable upgrade it was in router upgrade changed settings in router i had to call maker of comps an get them to reset ip adds took almost 3 hours to get them all working again they will do a remote access help by useing your ip threw your internet company hope this helps
4answers
Connection lost after a couple hours
Istall a good firewall! Sounds like spyware to me, probably something blocking new connection leaving the computer. You can try downloading ZoneAlarm at www.download.com, also try runnig asome anti spyware progs like spybot-search&destroy and Lavasoft's adaware good Luck
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
