20 Most Recent Linksys Wireless-G WUSB54GC (WUSB54GC-BP) Questions & Answers
hiiiiiiiiiiiiiiiiiiiiiiiiiiiii
Linksys... | Answered on Apr 25, 2017
Hi.
Linksys Wireless-G WUSB54GC Xp-sp2 v1.4 usb wireless adapter driver (xp sp1/2/3 + vista/win7/win8/mac) can be found at driverupdate us
It will take 2 mins from you to install...
I hope I have helped you...
enjoy
Linksys... | Answered on Nov 17, 2014
As long as you have the drivers it should be easy!
Linksys... | Answered on May 23, 2011
http://homesupport.cisco.com/en-us/wireless/lbc/WUSB54GC
Just follow that link select the downloads tab and then select the version of your hardware and you can download the driver. If you need any further assistance please let me know. Please take the time to accept/rate my solution if/when you find this information helpful.
Thank you,
Lee
Linksys... | Answered on Jan 15, 2011
try with Updating the Driver files with Adapter
Linksys... | Answered on Oct 06, 2010
The operating system on your computer is Windows 7 and the adapter is WUSB54GC. You are getting the Error 211 that means the drivers are not installed properly.
Though you have the CD of the adapter, you will need to download the drivers for the adapter from the web site.
Go to www.linksys.com/download , enter the model number of the adapter. select the proper version of the adapter. download the drivers for windows 7.
Now try to install the downloaded drivers. It will work.
Click here for more information about routers
Linksys... | Answered on Jul 14, 2010
install the driver first then click your micron trek then scan for your internet
Linksys... | Answered on Jun 29, 2010
It appears that the Windows service WLAN Auto Config was stopped due to an unknown reason. After re-activating this service I was able to install the wireless usb adapter 100% correctly. The Windows service WLAN Auto Config can be found if you run the program msconfig.
Linksys... | Answered on Dec 05, 2009
I have only tried this on Windows XP. If you can connect to the web using a hard line you can get this running. Make sure you have internet. Then plug the wireless adapter into the usb port and when windows ask if it can search the internet say yes. That will install a driver for the wusb54gc. Then windows will manage the device. Linksys only has the option to download the installer as opposed to just the driver. What a pain when the installer doesn't work.
Linksys... | Answered on Feb 25, 2009
Why dont you call their rma department? Here is there no. (800) 546-5797 (Option 3) and give them your rma no. so that they can pull up your information.
Linksys... | Answered on Aug 19, 2008
Here is a link to linksys WPA Setup page everything you should need will be there.
Click Here>>> https://www.linksys.com/ca/support-article?articleNum=139152
Linksys... | Answered on May 01, 2019
First and foremost, did you start with the Holy Grail of steps when dealing with routers?
30-30-30
YES! It does make a difference and it matters.
Hopefully you haven't bricked it (probably not).
If it is powered on, press and HOLD the reset button until the VERY END, DO NOT LET UP.
Holding the reset button for 30 seconds, then unplug the power and wait 30 seconds, plug power back in and wait 30 seconds. . . NOW you can let up on the reset button.
Now you can try and reflash the firmware, DO make sure you are using the correct version of DD-WRT for your EXACT model AND Version.
I have only done a few, but the 30/30/30 is crucial I am telling you!
Linksys... | Answered on Mar 04, 2019
Check the available memory on your PC. It may be limited and far too small for the operation you are running. Same thing happened to me
Linksys... | Answered on Jan 31, 2019
SADLY WITHOUT IT BEING A RECEIVER THERE MIGHT NEVER BE A WAY YOU CAN LINK IT UP
Linksys... | Answered on Jan 29, 2019
What is blocked?
Please explain in detail.
If your router is not working then I will suggest you to reset the router and reconfigure the router.
create a new wireless network and see if that works.
See How to setup Linksys router without CD.
Watch video:
How to reset Linksys router
Linksys... | Answered on Nov 28, 2018
not really unless you were to run an ethernet cable from your existing network to a location outside of the current wi fi range.
A repeater would be better
https://www.tomsguide.com/us/best-wifi-extenders,review-2225.html
It hears the wi fi signal so you put within the signal range near where the signal still can be heard near the extent of the current wi fi range. It will hear the signal and then re-transmit it to extend the signal range .
You might be able to use a gain antenna of 5dbi 2dbi is lost in the cable usually so it is 3dbi which is twice the level
http://computers.mwave.com.au/electronics/High-Gain-Antenna
another method would be a omni directional antenna facing the coverage range . But it is beaming in one direction .
which means more signal strength in one direction
https://www.mwave.com.au/product/draytek-ant1207-highgain-omnidirectional-indoor-antenna-black-ac04622
Linksys... | Answered on Nov 12, 2018
Linksys Wireless-G WUSB54GC (WUSB54GC-BP) Logo
17 questions posted
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Linksys Computers & Internet
Most Popular Question
linksys wireless g wusb54gc xp sp2
  • Computers & Internet
