I have a new Bosch Logixx Tumble dryer and the dryer will work for about 10 mins then alarms displaying the error message of -0-, ant clue???
SOURCE: How do I turn off
We had a similar problem with our Bosch dryer... every now and then when we were using the dryer an alarm would go off and it would stop drying. We checked through the manual and it had no information. Then one day I noticed that there was a flap on the end of the exhaust vent outside the house. As an experiment I propped the flap open so that it never fully closes. Now we never have the problem with the dryer. I suspect what was happening was that as the dryer was reaching the end of the drying cycle it was pumping out less and less exhaust to the point where it was too weak to open the vent flap, and the build up of exhaust in the ductwork triggered the alarm. I don't know if that's what's causing the alarm with your dryer but its worth checking.
SOURCE: f:23 code logixx edition75
Usually means there is water in the base pan and the flood safety has been activated. If you tip the unit forward a touch you will most likely find that water is expelled from the bottom front. The machine should work but obviously the source of the leak has to be found. Check door gasket for tears etc, water valves and drain hoses.
Hope this helps.
