Load an original in the automatic document feeder (ADF)
You can copy, scan, or fax a single or multiple-page A4, letter, or legal-size document by
placing it in the document feeder tray.
The document feeder tray holds a maximum of 20 sheets of letter or A4-size paper or 15
sheets of legal-size paper.
To send a basic fax from the control panel
1. Load your originals. For additional information, see Load originals.
2. Enter the fax number by using the keypad, press
Speed Dial or a one-touch speed
dial button to select a speed dial, or press
Redial/Pause to redial the last number
dialed.
TIP: To add a pause in the fax number you are entering, press
Redial/Pause,
or press the
Symbols (*) button repeatedly, until a dash (
-) appears on the display.
3. Press
START FAX Black.
If the device detects an original loaded in the automatic document feeder, it
sends the document to the number you entered.
TIP: If the recipient reports issues with the quality of the fax you sent, you can
try changing the resolution or contrast of your fax.
for further refernce check out the online manual
http://h10032.www1.hp.com/ctg/Manual/c01181836.pdf
