This is a common problem with the control panel assembly, which we repair nationwide for $39.95. This is most often caused by not disconnecting the microwave from the power line when removing or installing a bulb or by the filaments shorting when the bulb blows. If you or a friend decide to disassemble it to send the control panel in for repair, we have *critical* safety & disassembly, info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams by entering your full model number (without the suffix) here: http://tinyurl.com/gv383
Hello
& Welcome to FixYa
The
problem is with the fuse or the high voltage transformer that is bad and needs
replacement. Replacing the fuse will cost you under $100 from a professional
and getting the transformer replaced will cost you around $200. As the unit has
very high voltage inside so we don't recommend that this should be done by the
user. Please get back to me if you have any other questions.
Kevin
