GE JVM1653 Microwave Oven Logo
Posted on Nov 03, 2017
Classaction lawsuit We just fixed out microwave with the foil/bag combo. After spending $150.00 on a service call that went nowhere. Have you heard anything else about a classaction lawsuit for GE microwaves? If so let me know... Email: [email protected] Thank you, Tone Keys
  • William Miller
    William Miller May 11, 2010
    Can you explain what you mean by "We just fixed out microwave with the foil/bag combo."
    How did you fix it?
    What is the "foil/bag combo"?
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on May 01, 2007
SOURCE: GE over the range microwave making grinding noise
This sounds like the stirrer. If it sticks or stops, the microwaves can damage or destroy it. You may have a bad stirrer or magnetron. There is an important bulletin that covers these problems. To see if yours is covered, see: http://207.234.249.73/mwd/ge_mw_mag_kit_bulletin.pdf If you need more help, please follow-up.
Anonymous
  • 934 Answers
  • Posted on Dec 07, 2007
SOURCE: RECALL ON GE MICROWAVE OVENS
I am not finding it on the recall list put out by GE... They also have a toll free number 1-888-240-2745 if you would like to contact them directly...
Have a great day!!
Bill
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Jul 28, 2008
SOURCE: Model Jvm1440wh01
There should be a flame sensor (aka oven thermal cutout or TCO) located on the top left side or corner of the chassis.
You will have to remove the outer cover to find it.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Jul 05, 2009
SOURCE: WHat part number for this GW Microwave oven thermostat?
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
It will tell you where each one is located and what it's called, and should have the part numbers.
Three of them should read normally closed and one should read open.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If you still need help, let us know.
knightheatin
  • 149 Answers
  • Posted on Jan 14, 2010
SOURCE: How to replace the bulb in our GE Microwave Oven,
the outter cover wrapes around unit remove screws, be careful high voltage is present even with power off just replace bulb reassemble
1helpful
I WAS IN MY KITCHEN, STANDING NEAR MY MICROWAVE OVEN (i was not using it) I HEARD A LOUD BANG THAT FUSED THE TV, MICROWAVE AND SOME LIGHTS. I CHANGED THE FUSE IN MICROWAVE, P
If you put foil or silver of any kind in a microwave it causes an energy arc that may have hit a contact at a certain point inside the microwave causing damage that even if you weren't using the microwave as long as it was still plugged in still had a small amount of current going through it and had finally burst. which is why they manual advices consumers not to use reflective surfaces in microwaves. :)
My microwave keypad doest not work apparently. It says "service may needed". How can solve this error.
HELLO.
The solution to your microwave problem is explained below.
Things You will Need
* Phillips screwdriver
* Foil
* Large ziplock baggie
* Tape
* 1 Unscrew the 2 screws in the top vent grill and remove it.
* 2 Unscrew the 1 screw above the computer keypad, then slide it up to unlock it and it will hinge down, revealing the computer circuit board behind the keypad.
* 3 Put a sheet of foil into the large ziplock bag and seal it up.
* 4 Then tape it to cover the whole circuit board in the back of the computer. You may have to let the wires stick out of the middle of your foil covering. The ziplock is to keep the metal foil from short circuiting anything on the computer, and the foil protects the circuit board from the small amount of leaking microwaves inside.
* 5 Lock the keypad back up and plugin the microwave to test it before screwing everything back together.
Thanks.
1helpful
My GE microwave (model# JNM1541DN1BB) is giving me a message; service may be needed keypad shortage. Question 1 how can I fix it myself? Question 2 why did my microwave go out and how can I keep it from...
HELLO.
The GE problem is with the magnetron being to close to the computer. If your microwave runs for a few seconds to minutes then resets with funny characters on the screen, you can follow these simple instructions to fix it.
needed things.
* Foil
* Tape
the way to keep it from happening again is to use the microwave with more caution.
Willing to help to help on other problems.
Thanks.
1helpful
I have a GE Profile JVM2070sk02 Every thing works and lights up but touch pad will not take any input. Fan ,Boost and light work .
HELLO.
The GE problem is with the magnetron being to close to the computer. If your microwave will not take any input, you can follow these simple instructions to fix it.
needed things.
* Foil
* Tape
1. Unscrew the 2 screws in the top vent grill and remove it.
2. Unscrew the 1 screw above the computer keypad, then slide it up to unlock it and it will hinge down, revealing the computer circuit board behind the keypad.
3. Put a sheet of foil into the large ziplock bag and seal it up.
4. Then tape it to cover the whole circuit board in the back of the computer. You may have to let the wires stick out of the middle of your foil covering. The ziplock is to keep the metal foil from short circuiting anything on the computer, and the foil protects the circuit board from the small amount of leaking microwaves inside.
5. Lock the keypad back up and plugin the microwave to test it before screwing everything back together.
Thanks.
1helpful
Daughter put tin foil in microwave. Now it take 5 min to pop a half a bag of popcorn. And won't make a baked potato at all.?????
any exposed metal will burn up a microwave.Unless it is a very exspensive model,It will cost more for a repairman to fix than it would to replace
2answers
I put a metal pan with food inside my microwave oven. I heard a popping sound and there are now two tiny black marks pitted into the glass on the door. I can feel the two pitted marks from both inside...
Yes it is safe to continue using the Microwave as long as the integrity of the glass is not compromised and the pitted marks do not exceed 1/4 inch. The RFwave generated by the magnetron is a pretty wide RF wave beam.
If your really concerned you can take the unit to any appliance service center and ask that they perform an RF leakage test. There is really no other way to know if your leakage is within acceptable limits. I can tell you from personal experience that the ony microwave I ever saw demonstrated excessive leakage had either been dropped and had hinge or latch damage.
If your really worried about it and can not get to a service center you can do this test:
- Wrap a tall empty glass with a sheet of aluminum foil and place it about 3 inches away from the microwave in front of the area you where noticed the pitting.
- Run the microwave with a GLASS filled with water of equal size for 1 minute.
- Stand back 3 to 4 feet and watch for any signs of a spark on the aluminum foil.
- As soon as the microwave shuts off check the dry foil wrapped glass for any signs of heat.
(No heat.... no problem. Sparks or Heat = repair time.)
Thanks for choosing FixYa.
Kelly
A bag containing sandwiches that were wrapped in foil was put in the microwave for ten seconds to warm them. Of course no one realized that the foil was in the bag. The bag caught fire and the microwave...
The arcing that caused the fire also caused the microwave generator be over loaded and sent stray voltage into the chassis. Microwaves MUST have the proper coating in the oven or aching will occur all the time. IF the coating is damaged and it can be damaged in areas that you cannot see, you will be money and heartache ahead if you replace the whole thing now.
1helpful
Hamburger in foil wrap put in microwave - shorted unit out
Hi- The first thing here is safety. If the power supply is good- 120v at outlet- then address the fuse in the cabinet. Open door, remove screw(s) holding control panel, and tilt out panel. Fuse should be visible. Check for continuity. If bad, replace with 15amp appliance fuse. Plug in and check for operation. If fuse blows again, unplug and start looking at a new microwave. Let me know if this info helps. Have more if needed- Thanks- Ed
Microwave seems to operate normally but does not heat food
Test it. Put a bowl of water in the microwave and place a small (1 or 2 sq inches) piece of aluminum fold next to it. Power the microwave on for 2 or 3 seconds. If the foil sparks, the oven is creating microwaves and should be functioning correctly. If nothing happens to the foil, then you have no microwaves being generated by the klystron tube.
You can spend 80 to 150 dollars to have the oven checked and repaired or you can find another on Craig's List in your community for less than 100 dollars. Alternately, you can replace with a new one for whatever you are able to spend (from 95 to 600 dollars).
Reset clock, ge spacemaker xl1800 times out after 2-3 seconds
There's a simple fix for this. Unplug the unit. Take off the top grill with 2 screws. Remove the 1 screw that holds the touch pad unit. Lift up on touchpad unit and lift out. Put a piece of aluminum foil inside a large zip lock bag and tape it to the back of the touchpad unit and reassemble. GE put the magnetron to close to the control board causing stray microwaves to interfere with the board. The foil shields it.
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
