according to the downloadable user guide at toshiba support page , it appears , FUNCTION / SPACEBAR keys switches the landscape / Portrait modes . have you tryed that . good luck .
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
If you portable display has been accidentally rotated 90 or 180 degrees this is easily returned to normal for the Intel Graphics Display by pressing the following keystroke:
CTRL+ALT+UP ARROW
Windows XP/Vista Monitor Orientation Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish. Hope this helps
This actually happens a lot, and it's very tricky but simpleto fix. Here is a full list of keys that someone on another website sent me for screen orientation problems, in case it's ever useful.
Ctrl-Alt-Up - right side up
Ctrl-Alt-Right - 90 degrees
Ctrl-Alt-Down - 180 degrees
Ctrl-Alt-Left - 270 degrees
If these don't work you'll have to do it manually, There is an icon at the bottom of the screen (now maybe the top) for yourgraphics properties. Right Click it
Select--->Graphics Options--->Rotation---> and make sure"normal" is checked It will be weird with the screen inverted but give it a go.
Within Windows XP, certain video drivers or graphics card chipsets supporting 180 degree screen rotation can cause the Windows XP display to be presented upside down. This can be (but is not always) tied to lowering the screen resolution in some accessibility programs. To revert to a right-side up display, hold down the CTRL, ALT and UP (arrow) keys.
Try it if you have Vista or Win7
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
