Panasonic Toughbook 19 Rugged Notebook - CF-19K4RAX2M Logo
Question about Panasonic Toughbook 19 Rugged Notebook - CF-19K4RAX2M
My screen does not flip 180 degrees when i turn the screen around
When i flip the screen around to go from laptop to tablet the screen orientation does not change.
Posted by jeremy p on
Brian Sullivan
  • Panasonic Master
  • 27,725 Answers
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Posted on Jan 28, 2013
My acer screen is sideways. how do i fix it?
1helpful
Rotate screen back to normal
1helpful
My Samsung n120 screen is displaying only vertically - how do I go back to horiz display?
2helpful
My son has rotated the screen on my fujitsu lifebook s series so now it is upside down! How do i rotate it back? Please help!
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish. Hope this helps
Acer tablet troubleshooting
b>
2helpful
Change screen orientation
b>
1helpful
P c screen upsidedown
Hope this helps
2answers
MY SCREEN IS NOW VERTICAL WHAT DO I DO TO MAKE IT HORIZONAL AGAIN
RMB click on the back ground, click on preferences, adjust your resolution and orientation settings.
How do I orientate my screen so that i do not have to flip the computer around after i switch into tablet mode?
Press the button in the lower right corner of the screen marked with two arrows following each other.
Moreover, you can use Tablet Properties to set the orientation you desire as default when you flip to tablet mode.
Screen has rotated 180 degrees
I have lots of Dell monitors and none of them has the ability to flip the screen orientation built into them. What I suspect has happened is he accidentally hit a keystroke combination that activated a feature in your video card driver. If you have the built-in Intel Extreme Graphics read this link and let us know if it helps. http://engtech.wordpress.com/2006/08/01/stupid-windows-features-monitor-display-turns-sideways-or-upside-down/
Top Panasonic Computers & Internet Experts
Marvin
Marvin
Steve Nordquist
Steve Nordquist
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
