SOURCE: color wheel or fan?
Sounds like the color wheel has shatterd, thats a fairly common problem with that model.
SOURCE: RCA DLP TV needs color wheel replaced
I used the internet and found others who had the same problem. Two individuals had a brief description on how to replace the color wheel in a DLP TV. Three small torque screws and a ribbon connector was all that was need for removal; once the access panel on the back was opened. I would guess that this process is the same for all DLP TV's, with some small variations!
SOURCE: RCA HD50LPW62AYX2 50" - color wheel replacement procedure
REMOVE ALL SCREWS AROUND SCREEN AND REMOVE SCREEN. REMOVE 2 SCREWS HOLDING PLASTIC PIECE IN MIDDLE. GENTLY SLIDE OFF CIRCUIT BOARD (JUST GLUED FROM THE BACK). REMOVE PLASTIC PIECE TO EXPOSE OPTICAL CHASSIS. REMOVE THE LAST REMAINING SCREW FOR LIGHT FIXTURE. REMOVE 3 SCREWS HOLDNIN COLOR WHEEL. REMOVE RIBBON PLUGS AND REERSE THE PROCESS TO INSTALL. JERRY.([email protected]. LET ME KNOW HOW HAT GOES. i'M WAITING ON THE PART RIGHT NOW. WHERE DID YOU FIND YOUR PART? THEY ALL TELL ME THE PART IS ON BACKORDER. SEE YA!
SOURCE: sony dlp 42" bad color wheel or bad lamp?
If Lamp has never been replaced its possible ,but sony is well known for Bad light tunnels or the Light engine. Call UED for information and Part 1-800-648-6657 and if Lamp call Mats 1-800-628-1118
