My HD50LPW42 has started making a buzzing noise coming from the back left corning were the lamp is....
(More)
My HD50LPW42 has started making a buzzing noise coming from the back left corning were the lamp is. What could that be and how can I fix it?
the top and right side of the picture have a darker picture like in a shadow. about 3 in on top and...
(More)
the top and right side of the picture have a darker picture like in a shadow. about 3 in on top and 3 inches on the right
When turned on, there is a 1 - 2 second burst of audio, but no picture. "Unusable Signal"...
(More)
When turned on, there is a 1 - 2 second burst of audio, but no picture. "Unusable Signal" is displayed. I've tried both coax A and B and composite 1 and 2 inputs, all with no effect.
my television was working fine until a few weeks ago.. we turned it off and had trouble getting it...
(More)
my television was working fine until a few weeks ago.. we turned it off and had trouble getting it back on.. now we can't get it to come on at all.. the green light on the power button of the tv comes on for a second, it acts like it's going to come on but the power goes off and no screen is displayed... is it the capacitor, bulb.. what?
takes several attemps of pressing the power button over and over before unit finally powers on then...
(More)
takes several attemps of pressing the power button over and over before unit finally powers on then is very slow to start,pictures flashes and jumps several seconds then works Ok, Is this something simple or a replacement waiting to happen?
Lamp/bulb cooling fan is making a squealing noise. The number on the fan is AFB0812LL. Where can a...
(More)
Lamp/bulb cooling fan is making a squealing noise. The number on the fan is AFB0812LL. Where can a replacement be purchased? How does one make the actual replacement in the unit?
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
written by Ecollier2012
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
I received a full refund for this tv, Monday Oct 6, 2008. Thomson had a courier pick up this tv at my home 2 weeks ago. Just call the numbers I have...
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
