My ps3 freezes after 5 min. of playing and then little green squares pop up every where on my tv. Then if i turn it off and back on, it will do the same thing right away. PLEASE HELP!!!
The only thing I can recommend doing is backing up your info and then trying to get to the restore option under the ps3 before the green squares pop up, if you are not able then contact Sony before your lose your warranty.
iFixitI put up with it turning off of a couple of weeks and then the power cord blew up ... The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. ... After your description, I am starting to think that your power brick is the problem. .... in i cant donothing about if i was trying to play my gta4 in keep cutting off in 1 ...
Sep 14, 2015 - 5. Check Your Xbox 360 Hard Drive. Not only can the cache corrupt from .... I unplugged the console when it froze instead of turning the power off. ... hi my 360 keeps on freezing on any game i play and like the screen frezzes but .... It willnot, even after 6 goes, play, it freezes, and after about 2 mins, it ejects.
Try using a can of air to blow out the fan area. Even though its well ventilated it may be full of dust. It sounds like an overheating issue. Also look into aftermarket fan/cooling solutions, that dont plug directly into the PS3 and have there own outlet power plug.
well let me tell you what to do your ps3 is about to fail and not turning at all this is the first problem then the second problem is that the ps3 will not turn on at all it will bipevery time you will try to turn it on but there is a fix for this what have happen is that the GPU got to hot and now is not making a good contact with all the pin on the bottom of the GPU is sounds crazy you may say what this guy is talking about but believe me do something before it gets worse go to ebay and on the ebay home page enter the word ps3 reflow there you will see 2 guys that do this type of work because this is what you unit needs the GPU needs to be reflow and this will take care of this problem
PS3 is one of the most amazing gaming device but like other competitor gaming
devices (Xbox and Wii) It also has some problems like Freezing up. You may
check out the informative Article at ezinearticles Remedy
for PS3 Freezing up.
gaming devices (Xbox and Wii) It also has some problems like Freezing
up. You may check out the informative Article at ezinearticles Remedy for PS3 Freezing up
up. You may check out the informative Article at ezinearticles Remedy for PS3 Freezing up. '
up.You may check out the informative Article at ezinearticles Remedy for PS3 Freezing up
