SOURCE: refrigerator stopped working
ok whats the light that you see? i need to know what the bars are and or your email and i can email you the list for the codes.
SOURCE: SAMSUNG RS263OSH SIDE BY SIDE REFRIGERATOR DEFROSTED
sounds like a bad timer in the defrost cycle. Call a tech repairman
SOURCE: Samsung RS2533SW refrigerator is not cooling.
It sounds like a defrost problem and I will help you if you need. Thanks, Sea Breeze
SOURCE: refrigerator cools freezer wont model rb215labp
I know that model very well and I would like to know how long you have owned it and will you or can you find someone that can perform some electrical test fo you. When Samsung made that brand they made a major mistake on the defrost heater elements. They were woven into the evaporator coil. If less that 5 years old it should fall under sealed parts warranty. When I look at a refrigerator from here there are so many possibilities of what is going on that I ask that this is not where to rate my solution. I see that you mentioned the digital controls but are they visible or gone whacked out? Sea Breeze
Testimonial: "thanks very helpful "
SOURCE: model sr 52
Hi, all the things in your refrigerator are getting warm. The freezer
is thawing and when you listen closely you hear a click with a buzz,
another little click and then nothing for a few minutes. Then the same
thing starts all over again. You fear the worst and you are probably
correct. The compressor has decided that it will not start anymore.
When this happens, sometimes it is the fault of the capacitor or the start relay.
There is about as good a chance that changing these components will
work as it is that it will not work. If you can do the changing your
self then you should get the parts and do the work. You have half a
chance that it will work. If you will need to pay someone else to do
the work then you need to look hard at what it will cost you and what
the unit is worth, then decide to take a chance or not.
If you do decide to change the start components
then you need to make sure that you unplug the refrigerator long enough
the let the compressor cool completely. Even with new components a hot
compressor often will not start. Believe me if your compressor is
trying to start and can’t then it will be very hot!
If you end up needing to change the compressor, get a complete price so that you can make a good evaluation of the cost versus replacement.
Make sure that the replacement will not cost more than half the
replacement costs. Why pour money into something that will have
something else fail before too long? Also remember that federal laws
require a certification to handle refrigerants and persons doing the job need to recover or reclaim all refrigerants and handle them accordingly. A compressor replacement is NOT a DIY job. Specialized equipment is needed to do the job properly.
Take care
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
heatman101
heatman101
