It doesn't do it all the time but sometimes it simply goes crazy and continues to move around on it's own and click on things when I don't click. It seems to like the top left corner of the screen as well, it always goes to that corner more than anywhere else.
SOURCE: when i move the pointer arrow it sometimes clicks
Go to the mouse and pointer settings and change the one click open to double click options. It would be fine
SOURCE: computer screen flickers with horrizontal lines
sounds like the LCD cable connection to the motherboard is loose. if you can, refer to the manual to remove and reconnect the LCD cable connection to the motherboard making sure it is securely attached. if this does not work, test if the same display problem will appear to an external monitor once connected to the laptop. if it does, it would be a video card problem and you'll need to get it replaced. if it only happens to the laptop LCD even after reconnecting the cable connection for it, you may need to get it replaced. hope this helps.
SOURCE: on touch pad, the left and right click below the
Since the left button is a primary button it gets used quite a lot thus the button fails at some point in time.
Either the button has broken or the spring mechanism has broken.
Don't worry it can be repaired, claim warranty support if you can. The laptop needs to be partially disassembled and the buttons inspected. The button may need replacing.
Take care!
damnor01
Testimonial: "My son figured that the spring might have broken, but can't find a manual showing us how to disassemble the laptop, is there one available?"
It is nothing to worry about, it is one of many window glitches
SOURCE: My cursor moves around but to get any where or scroll I have to left click every time
Enter your control panel from the START menu select CONTROL PANEL open it scroll down to mouse and adjust settings there.
Step 1
1. Open Mouse by clicking the Start button, clicking Control Panel, clicking Hardware, and then clicking Mouse.
2. Click the Pointer Options tab, and then do any of the following:
• To change the speed at which the mouse pointer moves, move the Select a pointer speed slider towards Slow or Fast.
• To make the pointer work more accurately when you're moving the mouse slowly, select the Enhance pointer precision check box.
• To speed the process of selecting a choice when a dialog box appears, select the automatically move pointer to the default button in a dialog box check box.
• To make the pointer easier to find when you move it, select the Display pointer trails check box, and then move the slider towards Short or Long to decrease or increase the length of the pointer trail.
• To ensure that the pointer doesn't block your view of the text you're typing, select the Hide pointer while typing check box.
• To find a misplaced pointer by pressing the CTRL key, select the Show location of pointer when I press the CTRL key check box.
Change mouse settings
http://windows.microsoft.com/en-US/windows7/Change-mouse-settings
Step 2
If you are using touchpad, try reducing the Touchpad sensitivity and check
1. Click on the "Start" icon in the lower left corner of the screen. Select "Control Panel." Next select "Mouse" under "Hardware and Sound." You can also left-click the touchpad while the cursor is anywhere on the desktop. From that screen, choose "Mouse Pointers."
2. Select the "Buttons" tab at the top of the dialog box that opens. This shows the type of touchpad device installed on your laptop.
3. Set the touchpad for right or left-handed use from this dialog box. You can adjust the double click speed of your computer as well. When you finish making any changes, click "Apply."
4. Pick the "Device Settings" tab from the dialog box now. You can see the touchpad for your Vista machine highlighted on this screen. Select "Settings."
5. Read the information provided in the next dialog box. It gives you options for tapping your touchpad, using the buttons, scrolling, pointer motion and sensitivity.
6. Make any changes you want from the various topics. When you make a change, click "Apply." Click "OK" when you finish making all your changes.
7. Do some work on your computer for a while, If the touchpad is still too sensitive, return to the "Mouse" menu and continue to adjust the settings until you get them just the way you want them.
Step 3
If the issue persists try to perform a clean boot and check whether the issue is still persists.
Follow the steps mentioned in the article given below.
How to configure Windows Vista to start in a "clean boot":
http://support.microsoft.com/kb/929135
Note:Once the troubleshooting is over, reset the computer to start as usual.
Also I would suggest you to keep in touch with mouse manufacturer
Step 1
Step 2
Step 3
