I've been trying to get the best picture possible for my new tv. It's a HDTV LCD but to me the picture looks blurry when I'm watching a HD program. My son has a LG Plasma HDTV & it looks so clear & crisp when watching HD programs. That's how I want this one to look, clear & crisp! Is there a certain picture setting I should be using?
Any help would be greatly appreciated.
Thanks.
SOURCE: Picture not HD quality while watching HD channels
Make sure you are using an HDMI video cable for optimal picture quality. Also, you must be using an HD reciever.
SOURCE: BEST PICTURE SETTINGS FOR SAMSUNG 5044
Try this.... First, go into picture menu and reset it. Next turn contrast all the way up. Turn the sharpness all the way down. Make sure the tint is in the middle. Adjust brightnesses accordingly. If that don't work, just drop me a line and i will explain more
Best regards
CircuitCity
SOURCE: Recommended best settings for the TH-50PZ700U Plasma TV
Try this one and see if you like it!
Normal: No
Picture mode: Custom
Picture: +22
Brightness: +9
Color: -3
Tint: 0
Sharpness: 0
Color temp.: Warm
Color mgmt.: Off
C.A.T.S.: Off
Zoom adjust: (grayed out)
PC adjust: (grayed out)
-- Other adjust menu
Video NR: Off
3D Y/C filter: Off (grayed out)
Color matrix: HD (grayed out)
Block NR: Off (grayed out)
Mosquito NR: Off
Black Level Light
3:2 pull-down: On
HD size: Size 2
SOURCE: Code for cable TV remote - 26" Insignia 720p HDTV
I just bought a 32" Insignia NS-LCD32-09 using the Cox (suddenlink) remote and the code 0463 worked fantastically for me, Thanks!
SOURCE: Need remote code for Bresnan Cable 5-1 remote for Sharp 32" LCD
Apparently I didn't read the directions for code search closely enough (as it does work for my tv). So I will post them here, just to be sure people don't make the same mistake I did.
With the Device on;
1) Press "TV" on the remote control
2) Press and Hold the "Setup" button until the light blinks twice
3) Enter "9" "9" "1" to enter code search mode on the remote
4) Press the the "CH+" slowly until your TV turns off (if you accidently go to far your can press "CH-" to go back a code or two)
5) Press the "Setup" key to lock in the code, the light should blink twice if done correctly
Your device is now programmed, enjoy!
I BOUGHT 29FS6RLM LG ULTRA SLIM TWO DAYS AGO. I HAVE BEEN TRYING TO GET THE BEST PICTURE POSSIBLE FOR MY NEW TV.IT IS LIKE I AM WATCHING BLACK WHITE TV.THE PICTURE LOOKS WHITISH,MORE RED AND MILD BLUE,WHEN I AM WATCHING IT.PLEASE I NEED YOUR HELP.THANKS CHIBUZO MY E-MAIL [email protected]
