The fan on my rear projection Sony Wega model kdf-50e2000 is loud and sqeaky. I opened the lamp compartment and cleaned the vents of the dust which wasn't excessive.I have a steady green indicator, so I think I still have time on the lamp which is two years old. I hear the replacement fan is less than $20. How can I get to the fan to replace it?
SOURCE: Sony KDF-50E2000
The fan part number is: 178733321 and costs: $10.31 from TRITRONICSINC.COM
Dan
SOURCE: sony kdf 50e2000 fans not working now: read below...
hi, Why did you change the thermal fuse - specify the original problem, where the fans working before and need the correct model number before I can help you.
Model kdfe2000 is not listed anywhere.
SOURCE: sony kdf-50E2000
bad lamp driver, if you have already replaced the lamp. If not, try replacing the lamp WITH AN ORIGINAL SONY LAMP!. Don't waste time with cheap replacements, you get what you pay for.
SOURCE: sony wega kdf-50e2000 standdby light blinks 8 times
8 BLINKS B -10.5 IS OVER VOLTAGE (B-BOARD) If your a novice call Sony or a Sony authorized service center.
SOURCE: have a sony kdf-50e2000 pic clear but green
dbrian07, most of these problems are caused by a defect in the optical block or light engine, your description of the problem points out to this particular area. there are some websites that can give you prices for either rebuilt or replacement light engines, you will need to type in your complete model number, and SONY USA.COM has a website i think they also can help you with parts for this model. please leave your feedback if i answered your question. thanks!
Testimonial: "THANK YOU WILL CHECK WEBSITE"
