GE Profile Spectra JGBP90 Gas Kitchen Range
Problem for GE Profile Spectra JGBP90 Gas Kitchen Range
Ge spectra xl44
By chuket on Mar 14, 2007
The oven gets up to temperature and then the temp just falls. It's very erratic (sometimes it works). Could it be the temp sensor or the ignitor? Also the temperature lights stay on. If I reset the lights then it seems to work better.
Same Problem
Nov 22, 2007
-   ge spectra will get up temperature, preheat light stays on but wont maintain selected temperature.-   COOKLESS
Nov 06, 2007
-   oven comes up to temperature thens falls down,sometimes 50 degree's-   ronald blake
Nov 04, 2007
-   I have the same problem sence day one. I have had a gas tec changed the top burners and the one for the oven. Still to this day after 5 years the oven does start up but if smells like gas and never heats up to the temp. It will get to the pre temp but after opening the door to put food in it stinks. I will guess no Thanksgiving here again as we will go to the kids...-   xl44sucks
Best Solution
posted on Mar 26, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
It was the igniter. The gas would go higher and then lower. The oven would take an hour to heat up. The new igniter did the trick. Thanks for your help and that link to the new part.
Popular Solutions for GE Profile Spectra JGBP90 Gas
Questions and Unsolved Problems for GE Profile Spectra JGBP90 Gas
Do you recommend GE Profile Spectra JGBP90 Gas Kitchen Range?
Answer
Answer
The oven and stop top comes on, but the glass stove top will not heat suddenly. Had to turn the... (More)
Answer
oven stopped baking when the temp. probe shut it off (as planned, at 165) but it won't bake anymore.... (More)
Answer
5 yr old pie wont get done ckd with thermometer and 50 degrees cooler than what was set. how do u... (More)
Answer
the oven ignitor doesnt specify the degrees in bake time where can i find this
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE Profile Spectra JGBP90 Gas...:
Top Kitchen Range Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Kitchen Range Experts
Top Range & Oven Repair
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
(972) 859-0929
Honest, Dependable, Available &...
Accurate Appliance Repair & Parts Supply
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
