This is a tube television set, so yes, you will need a digital converter if you are using rabbit ears.
You need to get a Digital-to-Analog Converter Box with this TV.
This TV has not built in digital broadcasting tuner.
See here about the converter.
Sanyo DS20424 would require converter box after digital change over because this TV has no digital tuner inside.
Yes you will need it.A DTV converter box is an easy-to-install electronic device that hooks
up to your analog television set and over-the-air antenna. The box
converts the digital television signal into an analog format, making it
viewable on your analog TV set.
For more info. click on the below link:
http://dtvfacts.com/digital-tv-converter...
you have not listed your tv Brand Or model. Need to know both. I can't see what tv you have over there.
Any TV manufactured before 2002 might need the converter box to get the digital channels.
What is the model number of your TV?
Check this website for more info about the analog to digital transition.
If you are receiving OTA channels, you will need to have the converter box but if you have a cable TV converter or satellite receiver then you do not need the converter as the channels will come to the cable or satellite receiver and from there to your TV.
I have a Sanyo DS20424 color television set and would like to know if it requires a converter box for the digital change over.
Thanks
