Question about Sharp LC-20SH4U 20 in. EDTV-Ready LCD Television
Do I need a digital converter box to recieve a digital broadcast with a Sharp LC-20SH4U TV?
    Scholar:
  • 42 Answers
Yes you need a digital converter box. Your model has an NTSC Analog Tuner. It doesn't have a Digital Tuner. This is why you need the converter box.
For example, many companies like Comcast or Time Warner or TCI etc used to broadcast Analog Signals through their wires. Now they have broadcasted only Digital Signals. This makes either your TV Obsolete as a Tuner or you have to get a digital converter so your Analog TV can receive the signal.
Depending on your service, it may be worth your while to get a TV with a digital Tuner.
Then again, it also depends on if you are connecting a box receiver to your TV. For example, if you have Directv or Dish, you would then use your standard Video/Audio or Composite Cables to transmit your signal OR your Out to TV Coaxial whichever works for your receiver. Some receivers have already built in converters . You should really consider all the factors to decide and determine it based on the type of service you have or want.
Posted on Mar 09, 2011
I have a sharp LC-37G4U and can not get it to load over air channels. this a digital tv but the only way they would load is with a converter. how can I download over the air channels on the tv
Unfortunately, the Sharp Aquos LC-37G4U TV is an HDTV-ready monitor. It does not have an ATSC (digital OTA) tuner. The A/V Center box (TU-GA1U-S) that came with the TV has two NTSC tuners. You'll need the over-the-air ATSC to NTSC (analog) converter box or a stand-alone ATSC tuner DVR set-top box to get most OTA channels. There are only low power NTSC tuners that continue to broadcast; you will only receive those stations if you are close to their transmitters.
Crutchfield has a nice list of the specifications for the TV here: http://www.crutchfield.com/S-4LS7pNsldXK/p_70037G4U/Sharp-LC-37G4U.html . The manual has the full specifications for the TV on page 100. Crutchfield has the manual here: http://pdf.crutchfieldonline.com/ImageBank/v20040615154800/Manuals/700/70032G4U.PDF .
I wish that I had better news for you.
Oct 21, 2016 | Sharp Televison & Video
I have an older Sharp Aquos TV - model # LC-32G4U. I am trying to connect a digital antenna but it doesn't work. Anyone know if I need a separate digital tuner for this TV? Or what else might be t
There is no difference between a "digital" and analog antenna. Either antenna will capture the signal. What you need is a digital converter box to convert the over air digital signal to the older analog type signal your TV needs. You connect the antenna to the digital converter box, and the digital converter box to the TV.
Several years ago, the US government forced peopel to buy digital converter boxes or newer TVs that could pick up the digital signal. Either get a digital converter box or a new TV.
Oct 29, 2012 | Televison & Video
Will our Sony Television Model No KD-28-~DX 40U work after the [email protected]
No,as a tv alone only for recieving a free AIR DTV signal broadcasting signal tv channels.This tv is an analoge tv.U must hookup to any analoge tvs to a box that called a Digital Converter box to used to recieving free AIR DTV broadcasting signal for channels.U still can used it for any analoge tvs if u have a pay tv signal broadcasting channels services.
Sep 04, 2011 | Sony FD Trinitron KV-28FQ75 28" TV
Trying to hook up converter box to Westinghouse flat screen the converter is magnavox sdtv. I get autoscan but no channels are found. I do not have an antennae. Do I need one? Help!
If ur tv a LCD tv it is a digital tv.U do not require a Digital converter box to get the new DTV free air signal broadcasting tv channels stations.But u do require a good digital antenna for it to recieve a long an strong signals to recieve a DTV free air broadcasting tv channels stations.
Dec 07, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
How do I record a tv program with a Sharp A400 VCR? Videos will play on the tv, but I was not able to get it to record. Thanks.
Your VCR is no longer capable of recording "off air" tv signals. All tv stations are now broadcasting in digital format, your VCR is analog only. You can however get a digital converter box that will receive "off air" digital signals and convert them for recording on your VCR. CLICKING HERE will give you all the information you need to hook up the converter box... Good Luck!
Nov 10, 2009 | Sharp VC-A410U VCR
Does my LC-13S2U have a digital tuner?
Going over you manual for the tv, it doesn't have a digital tuner.
You'll need a digital converter box for broadcast channels.
Indoor antenna will work. But, an outdoor antenna will work best for reception.
If you need a copy of your manual, you can download one with this link:
http://www.sharpusa.com/files/tel_man_S2Useries.pdf
Jun 14, 2009 | Sharp Aquos LC-13S2U-S 13 in. EDTV-Ready...
Do I need a digital converter box for sharp 13VT N100
Yes you will need on because you are receiving a analog signal and will not decode the digital signal without one.Hoe this answers you question.
May 18, 2009 | Sharp 13VT-N100 Combo
Does the Sharp Aquous LC-13E1U receive digital or analog broadcas
It looks like your TV is not HDTV capable, so you will need a box when the conversion takes place next year unless you have cable box or satellite TV receiver.
Dec 20, 2008 | Sharp Aquos LC-13E1U 13 in. EDTV LCD...
Analog to digital conversion on Aquos?
First of all, the change is actually goping from analog over-air broadcasting to a digital signal. Second, if you have cable or satelite, you don't need anything. The only time a converter is required is if you use rabbit ears or an external antenna. In your case, the TV DOES have a digital tuner so you DO NOT need a converter in either case.
Dan
Sep 23, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Sharp LC-20SH4U 20 in. EDTV-Ready LCD Television Logo
457 people viewed this question
Top Sharp Televison & Video Experts
Ekse
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
