We've had the machine from new for five years, never had a problem until it just stopped grinding the beans. I had someone look at it and they said the blades were worn, but couldn't source any more but I am not sure whether they could be bothered.
The machine makes a noise as though it's about to grind and then just stops.
If you kindly confirm if you think it not fixable, I would really appreciate it.
Many thanks
Deborah Evans
Since your grinder makes noise and the problem occured suddenly, I would rule out a grinder problem. I am guessing that your grinder runs 10-20 seconds before it stops. If that is the case you need to look for a obstruction in the grinder or a failed microswitch on the doser. Either of these could cause the problem.
