Several times I turn off the oven, leave, come back later and find it back on at high heat. Very dangerous as the oven will be very hot and even the wall around it. What am I NOT doing correctly that allows this to happen or is it a faulty product.
I had a similar problem with my electric Frigidaire oven. F1 is a bad oven control. (clock). It must be replaced.Unplug the range. Remove the screws from the rear panel. Remove the wires from the clock or electronic oven control. Replace the EOC (clock) with a new control.
Hope it works for you as it did for me.
SOURCE: Gas oven won't maintain temp. It turns off after reaching temperature set.
Hi ya mate sorry to hear your having problems with you oven,
The problem wiht your oven seems to ba a faliure of the fsd/ffd, it seems to me that this device is not completey gone but is faulty.
This device is used as a safety feature on gas ovens and is there to turn the gas off to the oven when the flame has failed.
The way it works is that the intial small flame heats up the the phile at the end of the cappliary tube which is connected to a valave which realses the gas to the oven..
what you need is to have it change
hope this helps
washdoctor
cheers
SOURCE: Faulty electric oven (Ignis AKL828/AV)
I think you will find that it is the oven element that has shorted, causing the trip to go. The fan will still work, but with no heat.
Remove inner rear panel of oven, there you will see the element.
Remove and replace.
Plz rate my solution.
Thanks.
SOURCE: Fan not working in my flavorwave oven turbo platinum
you need to narrow it down What oven model is this the same oven that is used in dunkin donuts or subway. Are you getting any error codes. it is most likely a fan issue because if the mags were bad it woud not heat or cook at all. Also check the fuses and if there is a reset switch by the power cord try and reset that.
SOURCE: my 30" wall oven oven won't heat up. the clock
There is a safety thermostat (thermal fuse) on the back wall of the oven that interrupts power from L1 to the Bake and Broil elements. This fails open on an over-temperature or over-current condition. The oven needs to come out of the wall to replace it - best left to a tech unless you are experienced in such things.
Best Regards,
Bruce
www.fixyourboard.com
