"F09" is an Overflow Condition error. The following link explains how to diagnose the problem yourself:
http://www.fixya.com/support/r3608557-f09_error_code
Read through the information provided and check all the common sense things that you can easily eliminate, first. For more in-depth troubleshooting procedures, refer to the tech sheet that came with your washer. The tech sheet is located inside your appliance. To access, remove the lower toe panel under the door by removing the screws under the bottom front edge (you may have to prop the two front feet of the washer up for better access - a 2x4 works well for this). With the screws removed, the panel will drop down, then come off.
The tech sheet will either be located directly behind the toe panel, or affixed to one of the interior cabinet walls. The tech sheet includes troubleshooting tips, error code definitions, test points, diagnostics procedures and wiring diagrams. You will need to use the tech sheet to accurately locate and perform some of the steps I have outlined.
If you have questions about this repair, please post back and let me know. I hope this helps you.
