Tried holding down the end of cycle button for 3 seconds, says the control lock is off. if i unplug and replug the push to start button works.
If disconnecting power and then re-applying it resolves the problem you have a bad relay on the control panel and it needs to be replaced to actually resolve the problem. Note that there are two control boards right there in the front. Here is a diagram to use so you can get a visual of what I'm talking about.
http://www.partselect.com/ModelFrames.aspx?ModelID=615234&ModelNum=GHW9150PW0&mfgModelNum=&ManufactureID=3&Selected=B0DCARYP&Position=1&mfg=Whirlpool&Type=Washing-Machine&Mark=1
If all the functions are working as set when the machine is able to start, then more than likely the first board is the bad one, but to honestly know you'll need the machine in the state where it won't start, with the top off and access to the boards. With a volt meter you'll need to check to see if the assigned voltage is going from the first to second board. There is a wiring schematic in the machine somewhere that will give you all the specs on that.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
SOURCE: Whirlpool Duet HT Washer
I guess electric door lock just stacked. To prevent door breakage call to your local appliance repair company.
_______________________________________
http://www.allstarsappliance.com
SOURCE: Whirlpool 9400 Front Loader Washer Control Button Locked
There it was, the directions printed right there on the front of the washer. So simple, who would have looked?? Thanks for you help. mine is the GHW9300P
SOURCE: Control Lock light is on. Cannot get it off. cannot run washer
To unlock the controls Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off.
The washer must be empty and the control must be in the OFF
state before pressing the touch-pad sequence to start the test.
Starting the Test Mode
? Close the door.
? Push CONTROL/ON (if present on this model).
? Select the DRAIN/SPIN cycle.
? Select NO SPIN by pressing the SPIN SPEED touch-pad.
? Push PREWASH OPTION four times within five seconds. (If
PREWASH OPTION is not present on this model, press EXTRA
RINSE four times within five seconds.) C:00 will light up on the
display.
If the Starting procedure fails, push the PAUSE/CANCEL touch-pad,
then repeat the starting procedure.
Test Program Control
In order to advance to the next step of the test procedure, push
PREWASH OPTION touch-pad two times. If PREWASH OPTION is not
present on this model, press EXTRA RINSE two times.
Read more: Whirlpool
Duet Washer 'Control Locked' - The Laundry Appliance Repair Forum -
Do-It-Yourself Appliance Repair Help - ApplianceGuru.com: The Samurai
Appliance Repair Forums http://applianceguru.com/forum2/1540.html#ixzz1AbBWB73c
Get appliance parts at http://parts.fixitnow.com
