Question about Whirlpool Duet Sport HT WFW8400TE Washer
Says it is locked, how do you unlock it - Whirlpool Duet Sport HT WFW8400TE Washer
Posted by joefranksmit on
Dan Webster
  • Whirlpool Master
  • 8,220 Answers
Aparajita Batabyal
    Brigadier General:
  • 3,513 Answers
Hi
Hold the cancel button down for more than three seconds. Also press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. The control panel is now unlocked, and the washer is ready for use.
Lock the washer again by pressing and holding the "End of Cycle Signal" button until the "Control Locked" indicator light turns on.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Aug 05, 2011
Where are the fuses for the power dock locks on a 2006 montecarlo06ss
DR/LCK fuse 25 amp . located in the I/P block
Fuse Block - I/P
In the right front kick panel
Power Door Locks System Components
The power lock system consists of the following components:
• Body control module (BCM)
• Driver door lock cylinder switch
• Front passenger door lock cylinder switch
• Driver door lock switch
• Front passenger door lock switch
• Door lock actuators in each of the doors
• DR LK Fuse 20-amp
Door Lock System Controls
The Power Door Lock System is controlled by the body control module (BCM) and can be activated by any one of the following:
• A door lock switch lock or unlock actuation
• A door lock cylinder switch unlock actuation
• A keyless entry transmitter actuation
• An automatic door lock actuation (Personalization function)
• An automatic door unlock actuation (Personalization function)
Door Lock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the lock position, it switches the door lock actuator lock control circuit to voltage. Since the lock actuator unlock control circuits are at ground potential within the BCM, the door lock actuator motors transition to the lock position.
Driver Door Unlock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the unlock position, it switches the driver door lock actuator unlock control circuit to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the left front (LF) door lock actuator motor transitions to the Unlock position.
The driver door lock actuator unlock control circuit is a dedicated control circuit used only for the driver door lock actuator motor. This is done so that the driver door may be unlocked by itself using a keyless entry transmitter or an automatic door unlock function (if programmed).
Passenger Door Unlock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the unlock position, it switches the door lock actuator unlock control circuits to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the passenger door lock actuator motors transition to the unlock position.
The door lock actuator unlock control circuits are dedicated control circuits used only for the passenger door lock actuator motors. This is done so that the driver door may be unlocked separate from the passenger doors using a keyless entry transmitter or an automatic door unlock function (if programmed).
Mar 23, 2017 | 2006 Chevrolet Monte Carlo
2005 Buick Rendezvous you can hear the relay clicking but the door locks will not open and close
Check for broke wires inside the boot from body to driver door , this is a common problem . If you don't find broke wire's , pull the door panel to get at driver door switch . Check for voltage an ground circuit .
Rendezvous Door Lock System Components
The power door lock system consists of the following components:
Door lock system fuse into the BCM (BCM D 25A fuse)
Door Lock Operation
When the BCM detects a transition of either of the door lock switches to the LOCK position, it switches the door lock actuator lock control circuit to voltage. Since the lock actuator unlock control circuits are at ground potential within the BCM, the door lock actuator motors transition to the Lock position.
When the BCM detects a transition of either of the door lock switches to the UNLOCK position, it switches the driver door lock actuator unlock control circuit to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the LF door lock actuator motor transitions to the Unlock position.
When the BCM detects a transition of either of the door lock switches to the UNLOCK position, it switches the door lock actuator unlock control circuits to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the passenger door lock actuator motors transition to the Unlock position.
The door lock actuator unlock control circuits are dedicated control circuits used only for the passenger door lock actuator motors. This is done so that the driver door may be unlocked seperate from the passenger doors using a keyless entry transmitter or an automatic door unlock function (if programmed). This video on testing computer controlled door locks on a Subaru , doesn't matter . test yours same way > The BCM controls your door locks .
Are all of the power door locks inoperative from both door lock switches?
Oct 12, 2016 | 2005 Buick Rendezvous
2005 Chevy Equinox Driver & Passenger Door Unlock Relay. How To Remove & Install. They Are Power Locks. Front Doors Must Roll Windows Down Use Hand To Open Thanks. Ms. J. C.
Door Lock and Unlock Operation
When a door lock switch is activated in the lock or unlock position the BCM will receive a voltage signal on either the door lock switch lock or unlock signal circuits.
The BCM, upon receipt of a lock switch lock or unlock signal, will switch the appropriate lock relay control circuit(s) to battery positive voltage. This will energize the appropriate lock or unlock relay(s). The relay will supply voltage to the door lock actuator lock or unlock control circuits to one side of the lock actuator. Since the opposing side of the lock actuators are connected to ground through the other lock actuator control circuit and the normally closed contacts of the lock or unlock relay, the doors and liftgate will then lock or unlock appropriately.
Three relays are used to operate the lock. Driver door unlock, passenger door unlock and all door lock. This is done to isolate the driver door lock actuator so it can be unlocked by itself using the keyless entry transmitter.
Your door locks are controlled by the BCM - body control module (a computer ) . An a scan tool is a must to diagnose system operation . Your best bet would be to take your vehicle to a qualified repair shop . The only way you could try to fix this is by changing parts ! Suppose you find an replace a door lock/ unlock relay an that doesn't fix it ? There could be DTC'S stored in the BCM . Do you know what a DTC is ?
DTC B3132 All Door Unlock Circuit Low
DTC B3133 All Door Unlock Circuit High
Your
Aug 10, 2016 | Cars & Trucks
Passenger door locks don't unlock.
You need to understand how they work , do you know about automotive electronic controls ? Your switches are just inputs to the BCM - body control module !
Door Locks Power and Ground
For door lock operation, the IP Fuse Block supplies battery positive voltage, through the 15 amp DR LK/TRUNK fuse, to the BCM. The BCM uses this circuit exclusively to apply power to the door lock actuators. The BCM is also supplied a ground circuit, which it uses exclusively to ground the door lock actuators. When a door lock is pulsed, the BCM internally connects these two circuits to the appropriate lock and unlock control circuits to actuate the locking or unlocking functions.
When diagnosing door lock malfunctions, these circuits must not be confused with the other battery voltage and ground circuits of the BCM. The appropriate wiring schematic must be used to locate the correct circuits. Failure to identify the correct battery voltage and ground circuits of the BCM during diagnosis of door lock concerns may result in misdiagnosis and unneccessary parts replacement.
When the BCM detects a transition of either of the door lock switches to the Unlock position, it switches the door lock actuator unlock control circuits to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the passenger door lock actuators transition to the Unlock position.
The door lock actuator unlock control circuits are dedicated control circuits used only for the passenger door lock actuators. This is done so that the driver door may be unlocked individually before unlocking the passenger doors using a keyless entry transmitter or an automatic door unlock function, if programmed. When the keyless entry transmitter is used to unlock the passenger doors, the BCM requires a repeated unlock command before it performs the unlock function. However, when the unlock input is from a door lock switch, a single unlock command is all that is required to unlock all doors.
How to test computer controlled door locks
Sep 12, 2015 | 2006 Pontiac Grand Prix
Door lock dont always work
What door lock doesn't always work ? One or all of them . This is a complex set up for these door locks ! The switch is an input to the BCM - body control module . There is logic involved in the microprocessor , there are relays built in to the BCM ! Could have a DTC - diagnostic trouble code stored in the BCM ! Could be a bad connection at the BCM or master window switch ! A bad ground !
DOOR LKS fuse
Driver door lock actuator
GMLAN serial data link
Keyless entry transmitter
Passenger door lock actuator
Passenger door lock switch
Remote control door lock receiver (RCDLR)
The DR LCK fuse supplies battery voltage to the body control module (BCM) for the power door lock system. The BCM supplies and monitors a reference voltage to the driver and passenger door lock switches through the door lock switch lock/unlock signal circuit. Each door lock switch receives ground at G300 which is also the ground for the door lock and unlock relays located in the BCM. When a door lock switch is placed in the lock position, the reference voltage is switched to ground and the BCM senses 0.0 volts on the door lock/unlock signal circuit. When a door lock switch is placed in the unlock position, the reference voltage is switched to ground through a 1.5k ohm resistor that is internal to each of the door lock switches and the BCM senses approximately 2.9 volts on the door lock/unlock signal circuit. The BCM interprets what position the activated door lock switch was placed in based on the voltage drop.
The BCM, upon receipt of a lock or unlock switch signal, will switch the appropriate door lock/unlock relay coil control circuit to ground causing the appropriate door lock/unlock relay to energize. With the relay energized, voltage is applied to the door lock actuator control circuit causing the door to either lock, or unlock depending on what command was received from the power door lock switch or remote control door lock receiver (RCDLR). When a power door lock/unlock relay is not energized, the switch contacts are normally grounded through the BCM which provides ground to the appropriate door lock actuator for the lock/unlock function being performed. The power door lock/unlock functions are performed by reversing the flow of voltage through the door lock actuator control circuits. The BCM has three internal drivers for the power door lock system. Driver door unlock, passenger door unlock and all door lock. This is done to isolate the driver door lock actuator so it can be unlocked separately from the passenger door. For additional information concerning keyless entry, refer to Keyless Entry System Description and Operation.
This is one you may want to take to dealer or some other ASE certified repair shop ! To do this right you need a Tech 2 scan tool !
Ignition ON, observe the scan tool Door Lock Switch parameter while using the driver and passenger door lock switches. The parameter should change from Idle to Lock and Unlock.
If the value does not change, refer to Door Lock Switch Malfunction.
Command the doors to LOCK and UNLOCK with the scan tool, the door lock actuators should LOCK and UNLOCK when changing between the commanded states.
If one or more doors do not LOCK or UNLOCK, refer to Door Lock Malfunction.
Aug 12, 2015 | 2009 Pontiac Solstice Convertible
My 42 FD 9954 Philips flat TV monitor has a channel lock I can't get it unlocked what do I do
How to lock or unlock channelsTo lock or unlock channels:
  1. Press the Menu button on your remote control.
  2. Select Settings.
  3. Highlight System and press OK/Select.
  4. Select Parental/Purchase.
  5. Enter your Parental Controls PIN.
  6. Select Parental Preferences.
To lock or unlock all channels:
Select Lock All or Unlock All and press OK.
To lock or unlock specific channels:
Select Block by Channel > Add or Remove Channels.
From there you can select to Lock All, Unlock All, or
select specific channel(s) that you'd like to lock or unlock.
Jul 21, 2015 | Philips Televison & Video
Why wont my phone unlock
What method you have used to unlock it .It's locked to network or security.If it's locked with security code use default codes to unlock it.Default codes are 12345 or 1234 or 0000.If these codes do not work get free master reset code for Nokia DCT phones from the site Unlock-free.com and reset it. You need to unlock it from network lock use correct unlock code.I think you may used wrong codes to unlock it or it may be a cdma network locked Nokia phone.CDMA network locked phones cannot be unlocked.Visit the site Mobile-unlocker.com get the unlock code for all GSM network locked Nokia phones and unlock it from service provider lock.After unlock it you can use with any GSM network sim card in it.
May 23, 2013 | Nokia Cell Phones
Driver side door locking with remote but will not unlock, if i unlock it with key then remote will unlock all other door, if all doors are locked remote will not unlock the car. Once i manually unlock...
it is not the actuators, try a different remote, you may have an issue with the car security system/body computer not functioning on the unlock driver door command, one press of remote is unlock driver door and 2 presses is unlock the other doors.
Sep 01, 2012 | 2003 Mitsubishi Galant
I can't unlock my nokia 6234,, any suggestions
It's locked to network? To Unlock the Nokia 6234 use the Unlock code.Get the Unlock code from the site Mobile-unlocker.com
and Unlock it from network lock.You need to specify the Network and country it locked now?It's GSM Network lock means you can unlock it..CDMA Network Lock means you cannot unlock it.
Feb 13, 2012 | Cell Phones
BAD DISK BECAUSE PASSWORD LOUCK
Issue How to lock / unlock the hard disk drive.
Cause
A hard disk drive may be come locked or unlocked allowing or not allowing for software to have direct disk access. You may encounter an error indicating to unlock the hard disk drive in any of the below circumstances.
  1. Attempting to install another operating system.
  2. Attempting to fdisk the hard drive.
  3. Installing software.
Solutions
To unlock the hard disk drive
unlock x:
The x represents the letter of the hard disk drive that you wish to unlock. For example, if you needed to unlock the C: drive, type c in the place of x.
Additional information about the lock and unlock command can be found on our Lock / Unlock page.
To lock the hard disk drive
lock x:
The x represents the letter of the hard disk drive that you wish to lock. For example, if you needed to lock the C: drive, type c in the place of x.
Jun 16, 2011 | HP Computers & Internet
Whirlpool Duet Sport HT WFW8400TE Washer Logo
311 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
